Home > Technical > where can i find my OBD connector |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Should still have one, should be on the left, underneath the cubby.
Remove the cubby see if its hidden underneath. I know some morons cut them off!!! |
3rd Oct 2017 4:23pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
It usually comes up through hole under cubby box
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
hello there , i`ve removed the chubby , removed the cover , it has a lovely big grommet with a hole , which i assume is where the obd wire should be , but alas , i can not see anything in the area , not even a cut off wire . i`ll go underneath tomorrow night and see what i cn spot
thanks ady |
3rd Oct 2017 5:26pm |
black OBD connector with 12 inch of black cable tube that go into loom at the back transfer box at the top wires run down to ECU, ABS unit if fitted under driver seat box and 10AS alarm under dash
Click image to enlarge |
3rd Oct 2017 6:09pm |
Yesssss , cheers everyone , I fired up the led torch , located the black tube and then found disappearing 2" down the pipe the cut off wires , will get a socket n get it plugged in
Thanks everyone Ady |
3rd Oct 2017 7:14pm |
If you look on site shop OBD connector and per wired pins are available
3rd Oct 2017 7:19pm |
