Home > Technical > where can i find my OBD connector
razz
2001 Defender 90 Td5 PU Caledonian Blue
hello everyone , the defender has arived , 2001 td5 , thought i would plug my nanocom in and have a look , but where on earth is the connector , its not between the seats , its not in any under seat box , the center fuse box had a connector , but my disco lead is different , i have the blue plug lead , have i got one even ?
thanks ady
Post #654613 3rd Oct 2017 3:52pm
bankz5152
Should still have one, should be on the left, underneath the cubby.
Remove the cubby see if its hidden underneath.
I know some morons cut them off!!!
Post #654618 3rd Oct 2017 4:23pm
ibexman
It usually comes up through hole under cubby box Thumbs Up
Post #654619 3rd Oct 2017 4:23pm
razz
hello there , i`ve removed the chubby , removed the cover , it has a lovely big grommet with a hole , which i assume is where the obd wire should be , but alas , i can not see anything in the area , not even a cut off wire . i`ll go underneath tomorrow night and see what i cn spot
thanks ady
Post #654630 3rd Oct 2017 5:26pm
dorsetsmith
black OBD connector with 12 inch of black cable tube that go into loom at the back transfer box at the top wires run down to ECU, ABS unit if fitted under driver seat box and 10AS alarm under dash
Post #654644 3rd Oct 2017 6:09pm
razz
Yesssss , cheers everyone , I fired up the led torch , located the black tube and then found disappearing 2" down the pipe the cut off wires , will get a socket n get it plugged in
Thanks everyone
Ady
Post #654668 3rd Oct 2017 7:14pm
dorsetsmith
If you look on site shop OBD connector and per wired pins are available Exclamation
Post #654670 3rd Oct 2017 7:19pm
