Home > Technical > Td5 fuel pressure regulator
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Working out the correct part for my td5 defender
Most parts for Land Rover online will say suitable for either 1a 2a or 3a and 6a defenders, how do I know which one one is ? Can't find either in vin ?!
I'm sure the part needed for 2005 defender is LR016318? 3 pipe ? Parts removed says MSO000030 but cannot find this one at all. Gasket part number I believe is MSX000010
Anyone know ?
Is it possible to fit the wrong one? I know it's obvious and it will either has a 2 or 3 pipe entry but are they more than one of each ?
Many thanks
Alex
Post #654438 2nd Oct 2017 8:13pm
dorsetsmith
2 pipe fuel pressure regulator is used on 10 P head 1989 to 2001 fuel retunes inside head
3 pipe fuel pressure regulator is used on 15 and 16 P head pos 2001 to 2006 fuel retunes outside head retune pipe work runs from front engine back to fuel pressure regulator
MSX000010 Gasket part number for fuel pressure regulator below
LR016318 3 pipe fuel pressure regulator
MSO000030. is old part number for Land Rover Discovery 2 2002 to 2004 TD5 fuel pressure regulator S/S LR016318
Post #654441 2nd Oct 2017 8:26pm
Martin
Site Admin
Only 1 of each type - so either 2 pipe (10P engine up to and including 2001 model year) or 3 pipe (15P engine 2002 model year onwards).
The 1A/2A/3A etc you can't find in the VIN is the last two characters before the final six numbers. So lop off the last 6 numbers, then the last 2 on what is left is the model year code (A-Y, 1-9) plus the assembly location (A = Solihull).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654453 2nd Oct 2017 9:06pm
Alextd5
Cheers!
I didn't know if the diaphragm was different etc. I guessing the MSO000030 was fitted to disco and defenders when new ? As it the original one.
Alex
Post #654454 2nd Oct 2017 9:08pm
Martin
Site Admin
MSO000030 doesn't appear in the parts catalogue, it may be a production part number, or a casting/sub-assembly part number that can't be bought on its own.
But there have been a couple of supercessions, ending up at LR016318 for the 3 pipe and LR016319 for the 2 pipe.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654455 2nd Oct 2017 9:12pm
