Home > Technical > Td5 fuel pressure regulator |
2 pipe fuel pressure regulator is used on 10 P head 1989 to 2001 fuel retunes inside head 3 pipe fuel pressure regulator is used on 15 and 16 P head pos 2001 to 2006 fuel retunes outside head retune pipe work runs from front engine back to fuel pressure regulator MSX000010 Gasket part number for fuel pressure regulator below LR016318 3 pipe fuel pressure regulator ---------------------------------------------------------------------------------------------------- MSO000030. is old part number for Land Rover Discovery 2 2002 to 2004 TD5 fuel pressure regulator S/S LR016318 |
2nd Oct 2017 8:26pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6613 |
Only 1 of each type - so either 2 pipe (10P engine up to and including 2001 model year) or 3 pipe (15P engine 2002 model year onwards).
The 1A/2A/3A etc you can't find in the VIN is the last two characters before the final six numbers. So lop off the last 6 numbers, then the last 2 on what is left is the model year code (A-Y, 1-9) plus the assembly location (A = Solihull). 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Oct 2017 9:06pm |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 |
Cheers!
I didn't know if the diaphragm was different etc. I guessing the MSO000030 was fitted to disco and defenders when new ? As it the original one. Alex |
2nd Oct 2017 9:08pm |
MSO000030 doesn't appear in the parts catalogue, it may be a production part number, or a casting/sub-assembly part number that can't be bought on its own.
But there have been a couple of supercessions, ending up at LR016318 for the 3 pipe and LR016319 for the 2 pipe. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
2nd Oct 2017 9:12pm |
