Home > Puma (Tdci) > TDCi heater control valve options |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
we have heat control, in sync with the dial. I can knock just a whisker off the chill right around to cooking scones. My Defender and travels
1st Oct 2017 5:39pm |
yep Chris spot on, what was free eventually turned out not to be once it got the numbers. Seems marketing doesn't pay for web sights or owners get greedy, not sure what happened really.
I thought about paying the money, but I also had the with Defender around the same time and it all slid. Probably shouldn't have as I put a lot of work into those pages. Nowadays I just park the odd pics in the server space allowed by Defender2 or Aulro. If I were to pay I'd be happier to pay the owners of the web sights one use regularly and gets a lot more from than just housing pictures. My Defender and travels |
2nd Oct 2017 7:10pm |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
These sites are a real problem, as you know there are quite a lot of threads on here affected by this, a great pity, your thread looks as if it was very informative (I’m always looking for ways of spending more money on my Defender).
Anyway, won’t hijack this thread any longer, just hope you’ve got your own back ups! Chris 2010 Defender 110 Station Wagon, Santorini Black. |
3rd Oct 2017 11:22am |
Andres 90 Member Since: 19 Aug 2013 Location: Pärnu Posts: 7 |
Peugeot - Citroen part nr.6448P6
Fiat part nr. 77363342 https://www.eurofrance.pl/Heater-Valve-Jum...rrency=EUR You can find them as cheap as 25 eur (depending which manufacturer). Land Rover "Original part " is made in Italy by Denso, at least on my D130 it was. |
6th Aug 2018 8:10pm |
That's it, at last the buy price is starting to match the product quality.
Happy to report my alternative approach is going strong with heat control like never before. My Defender and travels |
7th Aug 2018 5:36am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
Good find, really useful to know. |
7th Aug 2018 7:47am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
Brilliant find!
7th Aug 2018 8:40am |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 208 |
Anyone tried this part? does it fit and work! |
25th Feb 2019 4:12pm |
Yes, I have it for some time.
It is exactly the same. |
26th Feb 2019 5:52am |
Thanks!
26th Feb 2019 7:42am |
more part number for same thing
ALFA ROMEO 77363342 CITROEN 6448P6 FIAT 77363342 LANCIA 77363342 PEUGEOT 6448P6 |
26th Feb 2019 8:58am |
Fantastic, I’m going to try and order one today so that is really helpful, thanks.
26th Feb 2019 9:53am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2031 |
I’m wondering if this valve would also be a viable alternative to the current Oem one. Noting it would need hose adaption but seems to have a cable controlled valve mechanism so easier to integrate into current setup.
https://www.ebay.co.uk/itm/16mm-5-8-Heater...2279138616 Points to note, all connections are 16mm so would need a 16mm to 18mm hose adapter for one heater hose. But these are only circa £3 on line .its metal not plastic but has a wide operating temperature range. It’s used in taxis, classic and self buil car applications. Unsure of quality. |
6th Sep 2019 12:11pm |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 92 |
The valve is that of Fiat Ducato!
6th Sep 2019 2:10pm |
