Page 1040 of 1385 <123 ... 103910401041 ... 138313841385>
ericvv
Bad experience which started yesterday. Without much preadvise on way home from work gear change started to become difficult, and in a matter of 2 km no more gear selection possible with engine running, so verdict, clutch kaput at 89.000KM. Actually lucky that it happened just outside town yesterday, better than somewhere halfway between Geneva and Entreq in Germany where we were supposed to be heading this morning. That trip and the works there will need to be rescheduled to later this fall.
Within half an hour of calling them, I was towed to temporary safety by our TCS (see pic) as this weekend we have a the visit of www.royal-de-luxe.com with their giant puppets which is drawing 1 million visitors and a total stop of all traffic in and around town. So truck has stayed overnight in that spot, then was winched onto a flatbed truck this morning at 07.00 hrs at which time it still was possible to transit town to drop it at our JLR dealer. Will surely be a new clutch next week, but will decide with dealer what all to change after they open up the truck next week.
Guess also a chance to look at the condition of the engine to gearbox shaft. Or, as my friend Olaf from Entreq Whatsapp'd me, "Die Zwischenwelle Getriebe/Verteilergetriebe unbedingt kontrollieren lassen!!!" Ja, selbstverstndlich doch, Olaf. Laughing
Eric
Now that I come think of it, second time on one month that the truck goes on a flatbed. Beginning September also on the french payage after a hose came loose. We should start a thread with Defenders on tow trucks/flatbed trucks. Laughing Laughing
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #653871 30th Sep 2017 5:13pm
Procta
installed my replacement rear wiper and motor system, so I now have a working rear wipe Bow down Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #653874 30th Sep 2017 5:19pm
Gutch1985
Gave it a bit of a wash an made some plans for it over winter
Post #653917 30th Sep 2017 8:08pm
L110CDL
^^^ Very nice Thumbs Up Clayton.
Keeper.
Post #653944 30th Sep 2017 8:54pm
AJC
Used the old girl to drag the trailer full of branches after doing some clearance work at my works yard. Then went home and fit door silk trims
Post #654015 1st Oct 2017 7:19am
LR90XS2011
another thread regards drive flange spline rust made me think that I have never checked my front drive flanges, so whipped off the wheels, drivers side rubber cap had a very very small amount of rust powder in it, removed the drive member bolts and cir-clip pulled off the flange and all was good nice snug fit but was dry with evidence of rust starting to form, passenger side was all like new, reassembled both sides with copious amounts of corrosion block grease. All in took 2 hrs but that included some time searching for flange gaskets and the thread lock I knew I had somewhere but couldn't find when I needed DEFENDER 90 TDCI XS,
Post #654085 1st Oct 2017 1:54pm
Cactus79
Swore lots at the previous owner for .... maintenance.
Post #654125 1st Oct 2017 4:36pm
Jacked the front of mine up on stands ready for some minor work tomorrow.
What lovely weather we have as usual. Rolling Eyes
Maybe it'll dry out by tomorrow who knows otherwise it'll be lying on the ground in the wet probably on soggy cardboard before I know it. WeWillWin🇬🇧🇺🇸
Post #654143 1st Oct 2017 5:17pm
VeeTee
Netherlands
Removed the cubby box and "under cubby box" with all the additional electrics, relays, etc. in order to prepare for the installation of a new upgrade:
a Roamerdrive. Very Happy
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #654152 1st Oct 2017 5:30pm
Martin 01
Got round to fitting bits I acquired at Peterborough.
Mantec RAI to replace my rusty metal one, nice straight forward fit.
Land Rover/Mantec spare wheel carrier curtesy of Duckworths. Carrier was easy enough to fit, however getting the boost alloy to fit correctly wasnt. Phone call to Duckworths who sent me out the extensions needed for alloy wheels FOC.
Fitted the extensions but then they stuck to far out meaning couldnt tighten up the wheel for Shocked
Another phone call to Duckworths & I was told had the same problem before. The way round it was to take off the large round threaded washer from my old wheel carrier & set them up at the correct depth on the extensions. This I did and it now all fit & works as it should Very Happy
Lastly put on some new rear mud flaps, just cut the old bolts off & used new bolts & washers.
Also recently had new gearbox, clutch, flywheel & all bits to go with it
Got the transfer box on order for fitting next Tuesday.
Hopefully thats enough spent on her for now.
Heres to another 230,000 miles Thumbs Up
Post #654184 1st Oct 2017 7:41pm
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Looks good Martin
Post #654212 1st Oct 2017 8:41pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hit a small milestone today,
 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #654235 1st Oct 2017 9:30pm
Jacked up all four corners one at a time, took wheels off.
Checked brakes, checked tyre's and picked all the grit out and stones.
Little point but isn't the best rubbish to have between treads.
All good thank goodness, was just due a check and that is enough for one day. Laughing WeWillWin🇬🇧🇺🇸
Post #654378 2nd Oct 2017 5:32pm
DAZ110
You will be doing it all again following next Saturday! Laughing
Post #654379 2nd Oct 2017 5:37pm
Rolling with laughter Shocked Just thought I may as well go though them as they were off.
Brakes were my main interest. Very Happy WeWillWin🇬🇧🇺🇸
Post #654383 2nd Oct 2017 5:44pm
