![]() | Home > Maintenance & Modifications > PUMA CLUTCH REPLACEMENT |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
I have seen the uprated ones on paddocks website....i guess they will be the same as heavy duty
Anyone used them??? |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I would be speaking to Ben Williams at Clutchfix for a new clutch buddy highly recommended 😊👍💪 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
If you go genuine, is there a difference between a clutch for a regular 122HP Puma and a 150HP Puma like on the Autobiography and Adventure last editions?
And would it make sense to ask dealer to install the latter on a 122HP Puma? What parts all need to be replaced to do a good job? Why do I ask? On the way home from work tonight, my clutch died without any real preadvise, just on a stretch of 2 km getting into any gear became the longer the more difficult, and then suddenly clutch was just kaput. ![]() First time it happens, 89.000KM Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 30th Sep 2017 7:35am. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Mine went under at 38k miles. I think the new genuine models of clutchbare a redesign. Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
Redesigned, yes, but they're still not much good!
![]() After 50k miles the springs have a permanent set and have lost their springiness. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Three listed here
https://www.lrdirect.com/LR029894-Superced..._https=yes Three more here http://www.paddockspares.com/catalogsearch/result/?q=LR048731 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Ok thanks
So you reccomend a normal clutch rather than a heavy duty one????? Mine will be getting tuned up so would be better to have stronger springs etc save it happaning again Thanks |
My concern with a HD clutch would be that it would make the gearchange heavier.
However, I cannot comment if this actually is the case or not. Chillin In The Backwoodsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Thanks steve,
Has anyone on here got a HD clutch or do i just go for standerd?? As its only the springs that are the problem atm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2449 ![]() ![]() ![]() |
Depends what sort of HD plate is. Some "HD" are noisy to very noisy at idle. Puma 110" SW
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 ![]() ![]() ![]() |
Didn't I previously read a post on here that the now current "standard" replacement clutch is an improvement to the item originally fitted to Pumas?
Pickles. |
^^^^ Yes, and I'm pretty sure it's true and originated from LR techs mentioning it,? Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
I believe it has already been improved/redesigned several times. But what does "improved" really mean? On a scale of 100 being perfect, going from a 10 to 20 is also already an improvement. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
There is a difference yes. The AB's did come with an uprated clutch, and you can order them. However the uprated clutch is about £1300 from LR - that's just the kit without labour. ![]() There is also a later type clutch slave cylinder too, which suposedly makes the clutch lighter, i didn't notice a massive difference on mine, but maybe it already had one. These are a reasonable price, but i don't know at which point they started fitting them as standard. |
