Home > Maintenance & Modifications > PUMA CLUTCH REPLACEMENT
arran jones
Hello All
Is you can see by the subject i might be needing a new clutch on my puma soon but will be getting in confirmed within the next week or 2
I expect most ppl on here have replaced theres.....does anyone recommend a Heavy Duty clutch kit over against the normal...obviously the hd ones are alot more expensive but do they actually make a bigger difference or not??
Thanks in advance Thumbs Up
Post #653574 29th Sep 2017 8:11am
arran jones
I have seen the uprated ones on paddocks website....i guess they will be the same as heavy duty
Anyone used them???
Post #653585 29th Sep 2017 8:58am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I would be speaking to Ben Williams at Clutchfix for a new clutch buddy highly recommended 😊👍💪 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #653693 29th Sep 2017 6:03pm
ericvv
If you go genuine, is there a difference between a clutch for a regular 122HP Puma and a 150HP Puma like on the Autobiography and Adventure last editions?
And would it make sense to ask dealer to install the latter on a 122HP Puma?
What parts all need to be replaced to do a good job?
Why do I ask? On the way home from work tonight, my clutch died without any real preadvise, just on a stretch of 2 km getting into any gear became the longer the more difficult, and then suddenly clutch was just kaput. Rolling Eyes
First time it happens, 89.000KM
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #653699 29th Sep 2017 6:37pm
Mine went under at 38k miles. I think the new genuine models of clutchbare a redesign. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #653701 29th Sep 2017 6:40pm
Redesigned, yes, but they're still not much good! Sad
After 50k miles the springs have a permanent set and have lost their springiness.
Post #653703 29th Sep 2017 6:46pm
spudfan
Ireland
Three listed here
https://www.lrdirect.com/LR029894-Superced..._https=yes
Three more here
http://www.paddockspares.com/catalogsearch/result/?q=LR048731 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #653712 29th Sep 2017 7:20pm
arran jones
Ok thanks
So you reccomend a normal clutch rather than a heavy duty one?????
Mine will be getting tuned up so would be better to have stronger springs etc save it happaning again
Thanks
Post #653718 29th Sep 2017 7:32pm
My concern with a HD clutch would be that it would make the gearchange heavier.
However, I cannot comment if this actually is the case or not. $W33T $0U7H3RN $UG4R
Post #653722 29th Sep 2017 8:05pm
arran jones
Thanks steve,
Has anyone on here got a HD clutch or do i just go for standerd??
As its only the springs that are the problem atm
Post #653734 29th Sep 2017 8:36pm
MK
Depends what sort of HD plate is. Some "HD" are noisy to very noisy at idle. Puma 110" SW
Post #653750 29th Sep 2017 10:31pm
Pickles
Didn't I previously read a post on here that the now current "standard" replacement clutch is an improvement to the item originally fitted to Pumas?
Pickles.
Post #653753 29th Sep 2017 10:41pm
^^^^ Yes, and I'm pretty sure it's true and originated from LR techs mentioning it,? $W33T $0U7H3RN $UG4R
Post #653756 29th Sep 2017 10:56pm
ericvv
Pickles.
I believe it has already been improved/redesigned several times. But what does "improved" really mean? On a scale of 100 being perfect, going from a 10 to 20 is also already an improvement.
Post #653780 30th Sep 2017 7:38am
zsd-puma
Eric
There is a difference yes. The AB's did come with an uprated clutch, and you can order them. However the uprated clutch is about £1300 from LR - that's just the kit without labour. Shocked The latest version 'standard' clutch from LR is only about £290.
There is also a later type clutch slave cylinder too, which suposedly makes the clutch lighter, i didn't notice a massive difference on mine, but maybe it already had one. These are a reasonable price, but i don't know at which point they started fitting them as standard.
Post #653801 30th Sep 2017 9:30am
