Home > Puma (Tdci) > Mud flap mounting
Page 1 of 5 12345>
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Mud flap mounting
Over the past few days I noticed a clunking/banging sound which seemed to be coming from the rear of my 110. I thought it was something inside the 110, but I looked hard and discovered the source... It seems that my right-rear mud flap has decided to detach itself. It cracked where the flap attaches to the rear quarter panel.
I don't know how it happened... It wasn't like this last week when I washed it, and I've only driven on motorways ever since. Bizarre.
I've got to bring it in to the dealer for about 7 or 8 other minor issues to be sorted under warranty - is it worth speaking to them about this?
Post #65167 26th Mar 2011 8:29pm
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
i know it doesn't help now, but when i fitted some checker plate there, i noticed that the panel lip was a tad thin...
i found that the newly fitted plate and a larger washer top & bottom, seemed to 'beef up' that bracket attachment.
food for thought, if your in for repair.
Post #65171 26th Mar 2011 8:53pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I was only asking yesterday whether Entreq had finalised their modification of the mudflap hanger as they too have noted that the rear quarter panel is a poor choice when it comes to hanging a mudflap and can result in unnecessary damage to the panel if you are unlucky enough! Entreq website says that the mod should have been available August 2010!?
Post #65175 26th Mar 2011 8:59pm
mse
I would get them to fix it.
The front one on mine would work loose - but at it didnt shear or damage the metal Mike
Post #65180 26th Mar 2011 9:23pm
eutek
ti-fat-man wrote:
i know it doesn't help know, but when if fitted some checker plate there, i noticed that the panel lip was a tad thin...
Interesting.. I was planning on putting some chequer plate there anyway.
Post #65192 26th Mar 2011 10:12pm
Eduardo
Eutek,
I had the same failure in both mudflaps. Finally I decide to reinfoirce the panel with a L shape aluminium strip riveted to the panel.
Cheers Eduardo
Post #65200 26th Mar 2011 11:59pm
holmessato
2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I too have had exactly the same problem on the RHS. Never had it on any of my previous 110's!
Like Eduardo, I have reinforced the area with stips of alluminium top and bottom of the origional lip.
Post #65203 27th Mar 2011 12:27am
rogerwd
This should be covered under warranty. Mine came off altogether - and I've also done a lot of motorway miles. In my opinion the stiffness of the mudflap is causing too much stress to the mounting on the body panel. The thin aluminium just cannot take it.
As it happens mine is going into the dealer tomorrow specifically to have this repaired - they are taking it to a bodyshop. My own temporary repair has worked well but I wanted an "approved" repair. Hope I don't regret it.
Regards
2010MY 110 County Utility Station Wagon
Post #65230 27th Mar 2011 12:24pm
Red Desert
Germany
what about a stainless steel reinforcement bracket for those, who do not like chequer plates ? Such a bracket could be made to low costs and would be very effective......
Post #65302 27th Mar 2011 9:20pm
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
I have had similar problems to those posted in this thread. My local dealer added a strip of metal to strengthen the mounting to the lower wing as warranty repair. I like the neat solution posted by Red Desert. Thumbs Up Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #65306 27th Mar 2011 9:31pm
Lorryman100
Olaf, have you this option for sale on your website yet? How are you getting on with the stainless rear replacement mud flap brackets?
Brian
Post #65314 27th Mar 2011 9:53pm
Red Desert
Germany
Brian
Brian......I just have finished the drawings for the rear Def 90 Mudflaps. I will finish the drawings for the rear 110 at the end of this week.
Post #65315 27th Mar 2011 9:55pm
Lorryman100
Cheers Olaf, I'll be ordering a set of rears once there ready Thumbs Up
Post #65318 27th Mar 2011 9:59pm
BIGFOG
Both ends for me please! (110)
Post #65319 27th Mar 2011 10:02pm
Red Desert
Germany
the rear ones will be a combination of stainless bracket and reinforcement......just give me some time to work a few details out
Post #65323 27th Mar 2011 10:11pm
Page 1 of 5 12345>
