Home > Puma (Tdci) > Mud flap mounting |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
i know it doesn't help now, but when i fitted some checker plate there, i noticed that the panel lip was a tad thin...
i found that the newly fitted plate and a larger washer top & bottom, seemed to 'beef up' that bracket attachment. food for thought, if your in for repair. Last edited by ti-fat-man on 26th Mar 2011 10:36pm. Edited 2 times in total |
26th Mar 2011 8:53pm |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
I was only asking yesterday whether Entreq had finalised their modification of the mudflap hanger as they too have noted that the rear quarter panel is a poor choice when it comes to hanging a mudflap and can result in unnecessary damage to the panel if you are unlucky enough! Entreq website says that the mod should have been available August 2010!?
26th Mar 2011 8:59pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
I would get them to fix it.
The front one on mine would work loose - but at it didnt shear or damage the metal Mike |
26th Mar 2011 9:23pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Interesting.. I was planning on putting some chequer plate there anyway. |
26th Mar 2011 10:12pm |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Eutek,
I had the same failure in both mudflaps. Finally I decide to reinfoirce the panel with a L shape aluminium strip riveted to the panel. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th Mar 2011 11:59pm |
holmessato Member Since: 11 Mar 2010 Location: Milton Keynes Posts: 27 |
I too have had exactly the same problem on the RHS. Never had it on any of my previous 110's!
Like Eduardo, I have reinforced the area with stips of alluminium top and bottom of the origional lip. |
27th Mar 2011 12:27am |
rogerwd Member Since: 23 Feb 2011 Location: Solihull Posts: 4 |
This should be covered under warranty. Mine came off altogether - and I've also done a lot of motorway miles. In my opinion the stiffness of the mudflap is causing too much stress to the mounting on the body panel. The thin aluminium just cannot take it.
As it happens mine is going into the dealer tomorrow specifically to have this repaired - they are taking it to a bodyshop. My own temporary repair has worked well but I wanted an "approved" repair. Hope I don't regret it. Regards 2010MY 110 County Utility Station Wagon |
27th Mar 2011 12:24pm |
Red Desert Member Since: 23 Aug 2010 Location: Lake Constance Posts: 53 |
what about a stainless steel reinforcement bracket for those, who do not like chequer plates ? Such a bracket could be made to low costs and would be very effective......
27th Mar 2011 9:20pm |
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 |
I have had similar problems to those posted in this thread. My local dealer added a strip of metal to strengthen the mounting to the lower wing as warranty repair. I like the neat solution posted by Red Desert. Paul
Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
27th Mar 2011 9:31pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Olaf, have you this option for sale on your website yet? How are you getting on with the stainless rear replacement mud flap brackets? Brian |
27th Mar 2011 9:53pm |
Brian......I just have finished the drawings for the rear Def 90 Mudflaps. I will finish the drawings for the rear 110 at the end of this week. |
27th Mar 2011 9:55pm |
Cheers Olaf, I'll be ordering a set of rears once there ready
27th Mar 2011 9:59pm |
Both ends for me please! (110)
27th Mar 2011 10:02pm |
the rear ones will be a combination of stainless bracket and reinforcement......just give me some time to work a few details out |
27th Mar 2011 10:11pm |
