Home > Tdi > High Mileage - Should I worry
zaz9
Malaysia 1997 Defender 90 300 Tdi SW Fuji White
Hi guys,
Just recently bought a 1997 90 station wagon with 300k on the clock. I know a lot of people have said to buy based on condition rather than mileage, which is why I bought it. Previous owner kept it well and service regularly, although I can't help but worry it will run into major issues?
Sorry for noob question just really love my Defender and want to maintain as well as I possibly can
Post #651742 21st Sep 2017 10:24am
Huttopia
No. Just enjoy it!
Post #651744 21st Sep 2017 10:32am
JOW240725
I'm no expert but my opinion would be that I'm sure the mileage was reflected in the price you paid for it so just keep it well maintained and if anything breaks it can be relatively easily replaced. Thumbs Up Enjoy it and post photos when you can! James
Instagram @suffolk_rovers
Post #651752 21st Sep 2017 10:56am
zaz9
Thanks for the reassurance James and for the warm welcome too. Going to get a fresh coat of paint and some upgrades here and there. Will post photos soon! Also your 110 is a beauty Thumbs Up
Post #651763 21st Sep 2017 11:31am
JOW240725
Please be aware I talk from what I've read with no real expertise!! I'm sure others will give you better advice!
Thank you for the compliment, our 110 is my pride and joy and mid-life crisis. Be warned this site could cost you a fortune with ideas and upgrades!! But that's the fun of Defender! Thumbs Up Thumbs Up James
Post #651766 21st Sep 2017 11:45am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
I always like to consider it as percentage factor to make me feel better doing a journey in a high mileage car.
Say you are doing a 600mile trip. A high miler will hardly notice the difference in miles while the low miler it will see a significant % increase. Which would you trust more?
Obviously it helps to know the high mileage car�s history and have the comfort factor that it is well maintained.
Post #651786 21st Sep 2017 12:21pm
Stacey007
Hello
Most older landrovers are like Triggers brush, Most parts can be replaced cheaply. Keep it serviced it should be fine Smile
Welcome and look forward to your pictures and plans Thumbs Up
Post #651841 21st Sep 2017 3:13pm
lb73
Wales
I had similar concerns when I bought my 300tdi csw, however having used it a main vechicle over the past 6months or so I've had no major issues. The advice I was given was as long as the chassis and bulkhead were solid, and dont be too concerned about wear and tear on mechanical parts as these can easily be replaced. Admittedly I did a bit of work on it when I first had it but that was more on the chassis/body areas.
So as others have said just enjoy it. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #652165 22nd Sep 2017 7:52pm
VeeTee
Netherlands
As others have said, enjoy it! If you service it regularly and keep it well maintained, high milage is no problem. My 300 Tdi from 1996 has 388 k km on the clock, it is my daily driver (and only car), and I trust it to start a 2000 km trip any moment. Thumbs Up Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #652171 22nd Sep 2017 8:24pm
TimS
United Kingdom 1997 Defender 90 300 Tdi CSW Arles Blue
Echo all of the above. Mine had 226k miles on it and the engine ran fine.
With that kind of mileage, there will be wear and tear on friction areas - bearings, oil pump, thrust washers, cam lobes and followers, crank journals, piston rings and bores.
Also seals will start to perish.
The 300tdi is a tough old engine and will run happily even with major wear. Just keep it well serviced and I would advise changing the timing belt, water pump and checking oil and combustion pressure to give you an idea whats going on.
Also check the turbo for play and excess oil and pop the intercooler and inlet manifold off to check them through and give them a good clean. If there is excess oil in these then you may have a turbo issue which is common at higher mileages and easily fixed.
Undoubtedly the previous owner had work done so its worth speaking with them to find out what has been repaired/replaced to give you some idea of what still needs looking after.
Its a simple engine to maintain and fix so get out and enjoy it!
Post #652180 22nd Sep 2017 9:28pm
LR90XS2011
Good advice from Tim
I know its slightly different but we have a fleet of over 200 mostly Cummins and Mercedes engines (slightly larger ones than ours) but we change them at about 450k miles, many of them exhibit no major wear when removed for overhaul, the duty cycle is a lot different however to the average car. DEFENDER 90 TDCI XS,
Post #652204 23rd Sep 2017 5:17am
zaz9
Thanks all for the advice! I'll be sure to enjoy every trip and maintain it properly. It's nice getting to talk to people here who love their Land Rovers as much as me (or even more! Laughing ) Here a few photos of my 90 before I make any additions and modifications (still deciding what colour to go with for the repaint)
Post #652205 23rd Sep 2017 5:25am
LR90XS2011
that looks smart, i think there were some timing belt mods in that era, suspect its been done but may be worth checking DEFENDER 90 TDCI XS,
Post #652210 23rd Sep 2017 6:26am
L110CDL
Welcome and a good looking landy you got there Thumbs Up As others have said about maintenance Thumbs Up regularly serviced will be a good thing, i service mine every 6000 miles and im on 317k now Wink enjoy your time with your landy Thumbs Up Clayton.
Keeper.
Post #652516 24th Sep 2017 9:25pm
oneten110
Congratulations on your taste. As others have mentioned, if they are looked after Defenders can do stellar mileages. I had a 300 110 from new and put 322,000 miles on it in 12 years. The only thing I did was to shorten the service intervals to 5000 miles once it got past 100,000 miles. Just to keep the numbers simple.
A friend has a truck that is approaching 700,000 miles, it started life as a V8 was converted to a BMW straight six and currently runs a Brazilian 2.8 Tdi.
My own v8 has done approximately 380,000 miles and is still going well, if expensively, lots of petrol and oil changes every 2,500 miles.
Post #652935 26th Sep 2017 1:25pm
