![]() | Home > Maintenance & Modifications > Wera Joker spanners (And general tool thread.) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20745 ![]() ![]() |
Arrived today. 😀
Click image to enlarge WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
![]() Click image to enlarge WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
They look lovely. Solved the bowel problem, working on the consonants...
Today I've used the Allen keys extensively, which is why I got them as I had a use for them coming up.
![]() They are very well made, very strong and of course won't go all rusty. The colour coding is extremely useful, as it's so easy to mix them up and waste time messing around trying to get the right size out. Shame they don't do a SS Torx version too, they don't seem to at the moment. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Update on an eBay company I've been talking to recently. (Won't mention names here.)
They already sell both the Joker spanners in standard metric and the Switch version. The normal type you can buy as a full kit, or as I did individually to break up the cost a bit. (And you can get the pouch.) They do sell the Switch version as a full kit but not currently on their own or with a pouch on its own. I have asked them if they would and they said they would a few months ago, I asked again recently and they said they still will but Christmas coming so likely will be the new year. All the same, good to know. Although the Switch version is seriously expensive! ![]() I'd love to see a Torx version of the Allen key set as pictured in my post in previous postings also. Maybe I should pop Wera a mail. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Torx...I'd be keen also.
I expect they'll point you in the direction of the Zyklops sets in the meantime: ![]() Click image to enlarge I larger versions I think will crack up to the larger Defender-ish sizes. But I'd rather be using a proper 3/8, 1/2 drive torx directly on the square than via adaptor. Solved the bowel problem, working on the consonants... Last edited by agentmulder on 18th Nov 2017 12:11am. Edited 1 time in total |
I'm also keen for the jokers in 21 and 24mm
![]() Meanwhile, here's an example I found online where the one-way versions fail: ![]() Click image to enlarge Process is as follows: 1. Prep the nut in the wrench. 2. Push manifold part on to the studs. 3. Fasten. 4. Remove wren ... 5. ![]() 6 ... 7. ![]() ![]() 8, 9, 10 ... 11. ![]() 12, 13, 14, 15 ... 16. ![]() |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2171 ![]() ![]() ![]() |
Got these myself Steve - as you say they are spot on. Too nice to use! ![]() I have a fair few of the Jokers too - again, a great product ![]() |
Well they are definitely better than Homebase that's for sure..
![]() Hoping they do a torx version of the same too. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Does anyone have any experience of the Zyklop metal 1/2" 3/8" and 1/4" ratchet and socket sets?
They look pretty good. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
At the begin of this thread I was going to say get Snap on but looking at the Wera spanners they look very good also I like the colour code for size,now I have to wear glass's I can't see the size's on the polished spanners ,there is another make which is worth a look and that's Bahco ,I have a set of their adjustable spanners and my son has a 103 piece Bahco socket spanner set which is very good.
Bahco are pretty good too, I have one of their pruning saws. All together different subject that though.
![]() I've got quite a few Wera tools now, never been dissapointed with any of them. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Got the Bahco, Facom and Zyklop all in 1/4".
All great. Zyklop preferred because of the obvious extra functionality, a friend has the 1/2" Zyklop, solid stuff. Small plus, but the soft Wera folding pouches also win over the standard plastic stuff everything else comes in nowadays. Solved the bowel problem, working on the consonants... |
Sealley sell a kit that looks identical at a cheaper price. I wonder if they are made by someone else and just badged up for the end seller. Ray My build thread http://www.defender2.net/forum/topic17615.html |
