Home > Technical > Main relay on Defender? ** Car still randomly cutting out **
Page 1 of 5 12345>
Stacey007
Hello
Following my other tread on my car randomly cutting out its still doing it... this morning while idle on the drive doing nothing...
Spoken to a House electrician (friend) and he thinks it more likely a main relay as ALL electrics go off including engine rather than a part or earth lead?
No codes found or showing.
So I messed about with the relays and fuses then we did around a 50 mile drive today and it cut out twice... all off just driving along.
Does anyone now which of these is a Main relay please? id it just one?
Thanks Smile
Post #649389 10th Sep 2017 5:18pm
dorsetsmith
2.4 or 2.2 defender ?
Post #649393 10th Sep 2017 5:35pm
Stacey007
Sorry should have said 2.4 thanks
Post #649421 10th Sep 2017 7:05pm
dorsetsmith
Post #649478 10th Sep 2017 9:10pm
Stacey007
hello
Thanks is it this one then?
Post #649481 10th Sep 2017 9:16pm
Stacey007
In fact no.2 and no.3 look to be the same relay?
So worth changing?
http://www.paddockspares.com/ywb500060-relay.html
Post #649483 10th Sep 2017 9:26pm
X4SKP
Hello Stacey007
Yes you are correct... 2, 3, (5, 6 and 8 if fitted are all the same) YWB500060
Worth keeping a Spare in the Vehicle, also when changing over, ensure there is a really good positive connection into its receiving connector...'nip up' receiving connector block female connections, also you can give a slight (a few degrees) twist to the spade elements on the new Relay to help it make a good connection when inserted.
My 2.4...
Hope you sort your issue... SKIP
Post #649548 11th Sep 2017 10:28am
Stacey007
Thanks,
Rang dealer as want an Original one, only £6.05 ex vat
Also my local garage this morning rang an auto electrician he said it could be the Switch behind the ignition?
This part is £48.09 ex vat so let's see if changing the relay first does anything?
I hope so....
Post #649552 11th Sep 2017 10:53am
X4SKP
Hello again...
I'm no electrician but what is this
you (your auto electrician) speak of... Question
My 'logic' says that there are two things going on here...
1 every thing needs to be right to start the vehicle
and
2 certain things need to be right and maintained to keep the vehicle running...
You appears to have an issue with the second, so now the question is what are these 'factors' (systems)
that appear to be 'intermittent'... Question
A Vehicle cutting out...(while running) is worrying... Shocked
As maddening as it was at the time I think I would have preferred my intermittent Starting Problem,
eventually traced to a single connection on the ignition switch.
Good Luck... SKIP
Post #649561 11th Sep 2017 11:35am
Stacey007
Hello
I will collect a couple of relays after work,
This is the switch behind the ignition? , the bit you put the key in this must connect on the other end? the garage the auto electrician uses has seen this wear before now?
I will try the relay first though..
Too be honest, myself and the garage would prefer the car to stop, not start and throw out a fault code... then we could trace the problem change the bit and all would be good,
Driving along 'waiting for it' to stop isn't the best.... Big Cry
Post #649578 11th Sep 2017 1:23pm
X4SKP
Hello Stacey007
OK I get it now... Thumbs Up
I also agree, 'break and stay broke' at least gives you a fighting chance...
rather than the 'will she or won't she' stress of an intermittent fault... Shocked
I too had No Fault Codes...
Main Ignition Switch from below...Key on the left...'replaceable' Ignition Switch 'Contacts Unit' on the right...
I didn't know this was a replacement item, there is next to no room back there, so without removing the whole unit from the steering column I can imagine its a real... Censored to do. The overall unit (assembly) has security headed bolts that look to require knocking out (drifting around with a center punch would probably work) but if you (someone) can get to the rear of this then best to leave in place...
Main Ignition Switch from above another view of set up looks to be a cross point screw (or 2) towards the rear that may be involved in securing the Ignition Switch Contacts...
Close Up
This is the best Close Up I have...for me the 'culprit' was the Red White wire, switching the power back to the Starter Relay (No 3) the connection was just poor...
I still don't see (understand) how when the Vehicle is running these elements if they fail would stop the Engine as their job is to start it... (someone on D2N will know)
Good Luck SKIP
Post #649583 11th Sep 2017 2:00pm
Stacey007
^ I took the dashboard pod out the other night.
Wiggles all the wires I could find while engine running and nothing happend. You're right it looks like a pain to swap the part on the right but mechanic seems to think ok? so it's on order.
The mechanic is still at a loss why it cuts out, I'm no better off and not sure where to turn. My friend who is a house electrician says he will try and find the wiring diagram for this car and look at this. He is sure it's to do with a main relay (I've changed) and no earth straps,
I had a week out of it last week, driving fine. then on Saturday for no reason just cuts off. When I say cuts off... You're driving along (although its also stopped on the drive while doing nothing) and then nothing.
No Dials
No engine
No power steering
Mileometer and trip go off.
You roll to a stop turn it back on and it's fine again... it will drive normally for a week or more before anything happens again. NO fault codes either...
I'm going to try to reseat the relays... but not sure what I can do?
Post #654344 2nd Oct 2017 2:07pm
Have a chat with Gary @ Alive.
It's starting to sound to me possibly electronic.
There is nothing to say that the ECM may need replacing if all else fails, it has been known but rare. KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #654345 2nd Oct 2017 2:12pm
Stacey007
^ E-mail send Thumbs Up
Post #654352 2nd Oct 2017 2:36pm
Martin
Site Admin
The OEM (non LR branded, same part) of the switch is about £17 rather than £57
When it cuts out:
Does the radio go off?
When the mileometer comes back on has the trip counter reset back to 0.0?
Do other things running (wipers) go off?
Does wiggling the key rather than switching off and back on again do anything?
There's not one single "main relay" which controls ignition switched circuits, the switch itself handles the most of the power. There is an additional ignition relay controlled by the main switch but that is for the wipers/washers, and heated seats/electric windows (if fitted).
The engine ECU detects the ignition coming on and then powers up its own relay.
Sounds like it might be the switch, with the ignition contacts opening up and cutting the power.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654354 2nd Oct 2017 2:44pm
Page 1 of 5 12345>
