Home > Technical > Main relay on Defender? ** Car still randomly cutting out **
Page 3 of 5 <12345>
Interesting! Thanks Martin. Thumbs Up
Post #654773 4th Oct 2017 9:52am
Martin
Site Admin
Martin wrote:
Sounds like it might be the switch, with the ignition contacts opening up and cutting the power.
Oh yes Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654774 4th Oct 2017 9:53am
Stacey007
Thumbs Up
Great, Have to admit when I took the dashboard pod out and the lower panel, looking at fitting this part looks a right pain...
Very fiddly?
Hope it arrives soon
PS< it's been fine for 3 days again Smile
Post #654775 4th Oct 2017 9:55am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
depending on what else cuts out, I am still voting for the crank sensor or wiring. V8 90...WIP
Post #654777 4th Oct 2017 10:06am
Martin
Site Admin
I've only done it on a pre-Puma and I removed the key barrel/column lock. However the Puma workshop manual suggests this is not necessary. I think this is because only one screw is now fitted not two.
Removal
1. Remove instrument cluster.
2. Remove steering column shroud.
3. Note position of harness leads on back of ignition switch and disconnect harness leads. If fitted, remove anti theft system passive coil from switch.
4. Remove single screw and withdraw ignition switch from steering column lock.
Installation
1. Fit new switch in steering column lock.
2. Connect harness leads to ignition switch.
3. If applicable, fit anti theft system passive coil.
4. Fit steering column shroud  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654778 4th Oct 2017 10:07am
Martin
Site Admin
This doesn't explain dash turning off completely, or things like indicators not working. Also it should appear as a fault in the ECU.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654779 4th Oct 2017 10:10am
Stacey007
Thanks Martin
Yes no fault code. My machine or garage
Does not sound too bad a job? Thanks for help I really hope it solves it
Post #654780 4th Oct 2017 10:18am
After rereading the thread I would concur that the ignition switch itself is a likely contender and needs to be checked.
Removing and replacing the ingition key/lock/switch is a hassle due to the use of shear-bolts, but it occurs to me that you may be able to diagnose the switch by unplugging the four connectors from the old switch and connecting the new one in its place without actually fitting it. The new key switch could be operated with a screwdriver to simulate the key (remember though that the key will still have to be turned to release the steering lock). It would rather depend on access and how much slack there is on the wires.
The black connector (C0028) is the power in to the switch.
The green connector (C0099) is the power out in the Aux position.
The 'natural' connector (C0094) is the power out in the Run position.
The red connector (C0090) is the power out in the Crank position.
A further alternative which would be easy enough if you have suitable wire and connectors and are handy with vehicle wiring would be to make a simple harness to connect the black, green, and natural connectors together outside the switch. As you have a switch on order though it would be simpler to use the new switch.
Post #654785 4th Oct 2017 10:32am
ARC99
Just another suggestion/question.
Is it possible for the vehicle alarm/immobiliser to kick in while the engine is running? Don't make old people mad.
Richard
Post #654797 4th Oct 2017 11:09am
Martin
Site Admin
Possibly, but it wouldn't cut all ignition power.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #654798 4th Oct 2017 11:10am
ARC99
Of course. Bow down Don't make old people mad.
Richard
Post #654801 4th Oct 2017 11:16am
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
How have you been getting on? Any further to finding the culprit?
Post #657187 13th Oct 2017 11:40pm
Paulv8
I agree about indicators not working. But I know from direct experience it doesn't trigger an ecu fault. V8 90...WIP
Post #657188 13th Oct 2017 11:52pm
Martin
Site Admin
Handy to know, thanks Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #657223 14th Oct 2017 10:02am
Stacey007
Hello
I had a week out of it and all was ok then 300meters from my house the other day just leaving for work it did it again...
New part is here, garage who is fixing up my Series III will do it ( it needs front discs also) but as he's started the boot on the series I don't want to take him off this job to look at this one...
Will report back once switch is changed.
Post #657352 15th Oct 2017 9:30am
Page 3 of 5 <12345>
