Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats
Page 46 of 81 <123 ... 454647 ... 798081>
mk1collector
Post #647967 3rd Sep 2017 1:40pm
Procta
love the roof console! I am toying with the idea of mounting my CD radio there, and have a set of gauges where the radio goes.
have not thought about the mud interior light? be nice to go with that I would have thought. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #647981 3rd Sep 2017 2:57pm
mk1collector
With the original Landrover interior light being black it looks really good and I already had LED bulbs fitted so it'll do me Thumbs Up Ray
My build thread
Post #647997 3rd Sep 2017 3:41pm
mk1collector
 Ray
My build thread
Post #648908 7th Sep 2017 9:49pm
L110CDL
Is it to do with the electric rear windows ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #648914 7th Sep 2017 10:06pm
mk1collector
Possibly Rolling with laughter Ray
My build thread
Post #649033 8th Sep 2017 5:18pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
They look like filled in disco window switch holders, so another vote for electric windows. If it is, it's well worth doing, I've done it on mine Thumbs Up
Post #649057 8th Sep 2017 7:32pm
mk1collector
Did you use the switch holder that came with the kit and bolt it to the back of the cubby? Ray
My build thread
Post #649063 8th Sep 2017 8:01pm
BuckBlu110
I didn't fancy the switches that came with the kit I bought, I wanted to use the oem switches so used a disco 2 sunroof switch panel on the back of the cubby, and the disco 2 cubby panel on the front so I could reach them easily, Ive re painted those panels so they're off at the min, but will hopefully get them back on shortly and get some photos up for you.
Post #649108 9th Sep 2017 8:44am
mk1collector
Interesting, so have you wired up two switches for each window then? That's what I'm planning on doing with switches in the back for the passengers and switches in the front so I can open and close them without reaching around. Ray
My build thread
Post #649130 9th Sep 2017 1:43pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
46 pages on your 110. It must surely be similar to Triggers brush with all the bits you've swapped Rolling with laughter
Catching the ferry from Hull soon for a boys Defender road trip.
If you need to work on Defender when it is raining then give me a shout - unit at Brighouse with illuminated pit Thumbs Up
Post #649134 9th Sep 2017 2:12pm
BuckBlu110
Yep, the original plan was to have the switches on the doors but there just isn't room as the switches are too long using the freelander switch holders I originally had, I thought the back of the cubby was the next best place as I didn't have far to wire the second switches, as with the oem switches, the rear switches have wires coming directly from the front panel rear window switches. Basically I studied a disco 2 wiring diagram, butchered the kit I bought and followed the same wiring as the disco. End result is that i can operate the rear windows from the front of the cubby and the back of the cubby when sat in the back.
Post #649136 9th Sep 2017 2:18pm
mk1collector
Rolling with laughter it certainly is like triggers broom Rolling with laughter when I've finished everything I want to do I think there will only be the roof, floor rear tub and engine from the original vehicle Big Cry
Might take you up on the use of the unit at some point Thumbs Up Where's the road trip to? Ray
My build thread
Post #649158 9th Sep 2017 4:44pm
mk1collector
Did you fit the window cut out switch too? Any tips or drawings you could send me on the wiring would be greatly appreciated as wiring is confusing to me. Ray
My build thread
Post #649160 9th Sep 2017 4:48pm
mk1collector
I've just had a look at the disco sunroof switch panel and realised it's exactly what I bought this week off eBay Rolling with laughter
I just thought is went on the centre console or something having only seen the picture they provided. Ray
My build thread
Post #649164 9th Sep 2017 5:06pm
