Home > In Car Electronics > Pioneer releasing the first single-DIN unit with Carplay
Page 3 of 11 <123 4 ... 91011>
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
It's my understanding it's the same unit, offering android And/or Apple car play? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #648798 7th Sep 2017 2:08pm
Si
It is the same unit. It does both. Mine has arrived Very Happy
Post #649023 8th Sep 2017 4:17pm
Vitesse
Update....... I stupidly forgot to order the ISO adapter. So the install stalled today. ISO arriving tomorrow and will try again! Rolling Eyes 2015 90 XS Santorini Black
Post #649044 8th Sep 2017 5:51pm
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Really interested to see how this goes.
Manual for any other nerds Very Happy
https://www.pioneerelectronics.com/StaticF...062217.pdf
Post #649106 9th Sep 2017 8:38am
Vitesse
Finally installed. Quite a job! Lots of fiddling and many wires. But what a difference ! Took me about 3 hours but it isn't straightforward as the wires are in the way of the rear metal bracket slightly. But it does go. The Dab module was also tricky to locate. I may have to re work it to make it more friendly to remove and replace. But very happy so far. I have to set the screen angle aswell. If anyone wants details of the install just pm me.
Post #649125 9th Sep 2017 12:45pm
Si
Top job. Did you use a DAB/FM splitter with the original LR aerial.
Post #649146 9th Sep 2017 3:42pm
Vitesse
Hi. The supplied box allows re use of the defender aerial for standard fm. The dab antenna is required but is not supplied with the kit. Brian. 2015 90 XS Santorini Black
Post #649152 9th Sep 2017 4:02pm
Tilly
United Kingdom 2010 Defender 110 Puma 2.4 USW Indus Silver
Collected one of these yesterday. Just need abit of time now to get it installed. There does appear to be a mighty cluster of wires to get in behind the dash somehow!
Post #649781 12th Sep 2017 9:32am
SteveG
2005 Defender 90 Td5 CSW Belize Green
What options do you have for adjusting the screen angle, and do you know what the range of angle possible is?
Thanks, Steve
Post #649793 12th Sep 2017 10:12am
Vitesse
HI Steve.....Page 8 of the user manual describes how to set the screen angle. I havent done this as yet.....
Very Happy 2015 90 XS Santorini Black
Post #649834 12th Sep 2017 2:02pm
Vitesse
Update........ I have now had the unit in the car for a few days and managed to set it up properly in relation to the screen adjustment and also just getting used to how it all works. I am pleased to say that it has fullfiled my requirements completely, In particular I like the fac tthe screen is higher up than the standard double din setup and this makes it easier to see. (in my opinion). The screen can be set to tilit and slide in and out as you need and it just perfect with a slight tilt to the front of the car.
When the screen is out, It does cover up the two inner switches but currently I have swaped them about so the inner ones are the fog and DSC switch. both of which are hardly used.....same for the hazzard switch. Considering moving theese to a Mud Puma pod on the dash top......
The screen is also remarkably stable given the crashing and banging inside the car Shocked
The install was quite difficualt trying to accomodate all the cables that come attached to the unit and I am going to pull it out again to improve the fitment in and out. I ran out of time at the weekend.......
Need to get a DAB antenna and also to create a good final location for theaerial amp that is supplied.
cheers for now..
Post #650226 14th Sep 2017 7:46am
Tilly
Fitted mine today along with a DAB/FM splitter for the original arial. Works perfectly on DAB and only heard one crackle while driving where the signal got lost for a second.
Post #650685 16th Sep 2017 6:51pm
Coatesyyy
Sorry, but can't beat a double din unit! Thumbs Up
Post #650985 18th Sep 2017 11:52am
Al_The_Pal
Apart from the £280 saving and not hacking your dashboard to mount the switches you have to move, and this way you can put the car back to standard.
Post #651136 18th Sep 2017 8:10pm
meeerrrk
sounds fantastic, thanks for the feedback guys...I'm sold! My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #651332 19th Sep 2017 4:26pm
