Home > My Defender > My 200 Tdi
Page 9 of 11 <123 ... 8 91011>
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Sorry Anorak
 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #647584 1st Sep 2017 8:01am
Procta
kit, just paint the beige, that colour was hot in the 80 Very Happy Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #647645 1st Sep 2017 2:58pm
Kit
Spent this weekend learning about spraying with a gun rather than a can Shocked
Finished cleaning up the other two with the angle grinder:
The most horrible tool in the world to use, literally got grit everywhere!
Nothing else does the job quite as well though!
Etch primer, the paint shop recommended this with steel wheels as it bites into any rust that I may have missed
High-build in the rough areas with normal priper around the rest
Changed my mind on the way to the paintshop and went for Alpine white in the end!
Base coat, this went on poorly and I think its because I used a cheap paint gun, it's not a bad finish (no runs) but its slightly stippled, like raptor paint? Fine on a 90 but I think you'd be scratching your head if it was a Ferrari! Razz
Clear coat, again went on pretty badly, just drenched the wheels, no matter what setting I put it on. That said the clear only left one run on one wheel, it also takes a long time to cure, so I decided to leave it until next weekend to sand it down and put a second coat on.
I think i'll buy a better paint gun this week, to see what the difference is, also a regulator and a moisture trap as there was allot of water coming up the gun to from the compressor (even though i'd emptied it).
Im still happy with the results, as this is the first time Thumbs Up
I also finished painting the back out (forgot to take a photo), seat risers from Fat Cog and seatbelt bars from gcc130 arrived (thanks guys!). The rear door retainer with rubber seal came today as well.
I've said this about five times already........ but hopefully i'll start putting it back together this weekend! 1993 200 Tdi 90 CSW
Post #648321 4th Sep 2017 8:52pm
Alpine white, yay Laughing Darren
Post #648329 4th Sep 2017 9:06pm
Kit
I know! I know!
Rolling with laughter 1993 200 Tdi 90 CSW
Post #648332 4th Sep 2017 9:15pm
Procta
Those will look great with a set of decent tyres, what's next on the list? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #648429 5th Sep 2017 12:02pm
Kit
Retrim the front seats, rear plastic window trim and get the rear seats/belts in, then it's back to the engine again with the boost pin/spacer & gauges after that it's electrics getting all the spots...etc wired up.
Hopefully in time for the October greenlaning session down sarrrf 1993 200 Tdi 90 CSW
Post #648555 6th Sep 2017 6:25am
L110CDL
Looking good there Kit with the wheels Thumbs Up Clayton.
Keeper.
Post #648689 6th Sep 2017 8:31pm
Kit
Starting to put the 90 back together now, so happy to see all the parts i've refurbished back on it!
NAS rear bumper and mudflaps on! Still need to do the tow electrics but I think this looks amazing, my dad most of this during the week.
Rock sliders on! Still need to drill in the 6 bolt holes for the outriggers
Fitting the new rear door seal, very happy with how this turned out, was dreading it not fitting
Wacked some more waxoyl on the night before, so it could dry over night
Fitted the steering guard
Test fitted the front bumper... which fouled at the recovery points on the steering guard recovery points iroinically... also the bull bar mounting plate overlaps the winch area...
angle grinder time....
I had to file the edges to tidy it up after my dad had cut it
Drilled a new hole at the front of the mounting plates to replace the anchor holes we had to cut off
Cut off the steering guard recovery points, also had to put spacers at the front and find new bolts as the top of the steering guard fouled on the bottom of the winch tray
Drilled holes in the front bumper
Bolted on the bull bar, should've painted the exposed metal here but I was moving too quickly at the time
Mounted the bumper for the final time, put on the bumper bolt caps and touched up the bar metal, ready for raptor refresh next weekend
I AM KNACKERED. 1993 200 Tdi 90 CSW
Post #649495 10th Sep 2017 10:15pm
Procta
looking great their kit! My bumper didn't really line up either compared to the original unit. its about a couple of mill out on one side. But I don't think these are really all that square. The rear bumper is the one I want for mine, but its something I have to work towards so I think that's going to be one of those jobs for next year sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #649506 11th Sep 2017 5:10am
Kit
I'm really happy with the final fit, getting there was a bit of a journey though!
Be careful with the NAS rear bumpers, there seems to be more than one type of rear cross member and the captive nuts in the bottom section are in different places! 1993 200 Tdi 90 CSW
Post #649515 11th Sep 2017 6:34am
Profyaffle
Thumbs Up Fantastic, that all looks very neat and well done. Looking forward to seeing the new wheels on 1993 200Tdi Defender 90
Post #649520 11th Sep 2017 7:17am
L110CDL
Its come along way to this point and is looking really good, as said, just the wheels now will make it look complete Thumbs Up Clayton.
Keeper.
Post #649661 11th Sep 2017 7:48pm
That looks great. It'll be really cool with white wheels Whistle Rolling with laughter Darren
Post #649677 11th Sep 2017 8:18pm
Kit
Yeah it's been a few months of hard work Thumbs Up
There's still allot more i'd like to do though 1993 200 Tdi 90 CSW
Post #650433 15th Sep 2017 9:57am
