Home > My Defender > My 200 Tdi
Page 2 of 11 <123 ... 91011>
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
When I say civilized I mean put the rear interior/carpets back in and turn it back into a mode of transport again rather than a toy. I've got nothing against the guys who go for the modern look, I feel the attraction of a defender is that it's so easy to make it your own.
Wheel wise, i'm probably going to go for the 4x4tyres black modulars and 265/75/16 tyres, I do like the idea of painting them white though I must say.
Post #610184 17th Mar 2017 9:25pm
Kit
Okay so a bit of an update, tatted around the 90 this weekend and did a few jobs:
Took the passenger side door off, had to drill out one of the hinge bolts and destroy the door seized door lock/handle unfortunately so i'll be buying a new set shortly.
Next I removed the rear lock, I forgot to get a photo of this but it looks like in a past life someone tried or did break into the back of the 90, probably why it's temperamental at times.
The bulk of my time was spent removing the crappy steps/sliders, in the end I just cut the rear hangers off with a a mix of 1 part angle grinder, 1 part hacksaw and 1 part frustration.
I'm going to order some of these tomorrow to replace them but i've got to do allot of cleaning up under the chassis next weekend before I can fit them.
http://www.rock-sliders.co.uk/landrover-de...iders.html
Post #610707 19th Mar 2017 8:37pm
L110CDL
Great start there Kit Thumbs Up Is that a McCormick in the back ground ? Clayton.
Keeper.
Post #610713 19th Mar 2017 8:49pm
Kit
Certainly is, that needs refurbishing too! Big Cry
Post #610737 19th Mar 2017 9:30pm
L110CDL
Looks an earlier one than mine ? hope to do mine one day Rolling Eyes Clayton.
Keeper.
Post #610741 19th Mar 2017 9:38pm
Kit
That's a 1957 if I remember correctly, it was left in a hedge for about 10 years before we got it
Post #610763 19th Mar 2017 10:42pm
L110CDL
Great that you saved it Thumbs Up Earlier than mine, but not sure on mines age Rolling Eyes Clayton.
Keeper.
Post #610769 19th Mar 2017 10:55pm
Kit
Post a photo up and I might be able to help?
Post #610902 20th Mar 2017 4:58pm
Profyaffle
<<<<< is waiting to see what a McCormick is.........
Post #610907 20th Mar 2017 5:11pm
L110CDL
Is this any good.....
If not, what pic do you want of it ? Whistle Clayton.
Keeper.
Post #610986 20th Mar 2017 8:27pm
Kit
I want to say its a 424 but the headlights are in the wrong place and the body panels are slightly different, my dad might know, i'll ask him on the weekend Thumbs Up
Post #611044 20th Mar 2017 10:14pm
L110CDL
Ok,many thanks Thumbs Up The lights are on the top because it has a front loader that goes on it, which i still have got and it is a 414 as it is stamped on the plate Whistle Clayton.
Keeper.
Post #611058 20th Mar 2017 10:38pm
Kit
Ahh yep, the front grille would've given that away, nice little project though mate... get stuck in!
Post #611062 20th Mar 2017 10:47pm
L110CDL
Will do, once the 90 has been finished, but i got to start it first Laughing Clayton.
Keeper.
Post #611229 21st Mar 2017 8:54pm
Kit
I spoke to my dad and he reckons that they made those B-414s in the 1960s but doesn't know much more than that about them.
So bit of a crap weekend even if the weather was good, you'll see why if you keep reading.
My dad took both sides of the lower panels off ready for me to start cleaning the bottom off, rust treating and putting the new rock sliders on:
Removed the door hinges and wing mirror so I could freely work on the passenger side door with the knackered door lock/catch:
This is the god aweful mess I found inside, do not scroll down if you're not a weetabix fan (the drivers side door is not much better):
Now there are lots of options available to me but i'm probably going to rebuild the door slowly, as if I buy a new one i'll need to respray the whole car and if by some miracle I found some good ones in the same color then they'd need blowing in too.
I decided to take some time away from the doors/locks while I considered the options and investigated the bulk head rust further, thankfully it was only surface rust, so my uncle chipped in and treated it for me while I worked on the wheels.
As mentioned I wanted to make this 90 more civilized and that means doing away with things like 12.5" wide tyres.
So I found these in my dads endless reams of stuff, which are apparently period correct for my Tdi?
Got the wire brush and some sandpaper on two of them, will try to prep the other two by close of play next weekend (I do have all the center caps):
Shall I do them in white or silver?
Post #612421 26th Mar 2017 10:56pm
