![]() | Home > Pictures & Video > Show Us Your Landy |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Strata Florida in Wales 3 weeks ago
Landie Boy Member Since: 14 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
Thanks ![]() Jack |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
Tack
Beautiful wide angle shot of the bomb hole ! |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1591 ![]() ![]() ![]() |
Did you do the bomb hole in your 110! I didn't dare! One of the other lads did in his 200tdi 90!
thanks bud, the wife took the pic ![]() rob, yep did it in the 110, did damage a rear mud guard but nothing too seroius ![]() |
carlaac Member Since: 09 Dec 2010 Location: Hampshire Posts: 58 ![]() ![]() ![]() |
Is that a Fox Wing on Thule roof bars? Works ok? |
Carlacc, yes thule bars, but I have added a side rail to it which can take an awning, the item on the roof is my RV2 Oztent not foxwing
Thanks for getting back, is the side rail something you bought or fabricated? I'm keen on the idea of a foxwing and oztent, but added to a roof rack starts adding up and wouldn't mind being able to take the rack off so I can still get in the local car parks! Does the foxwing zipped to the Oztent work well for you? |
Bomb Hole Pic :
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Seb, Down to the south you can found gas stations every 300 - 400 km. Main problem is that sometimes they don't have diesel or are closed at night (happens to me twice in the trip). For this reason 80 extra liters give me in the safe side. Taking a note that the yield towing the popup in bad roads has been reduced drastically to 6.7 km/lt. That gives me an autonomy of 971 km, far enough to found a gas station if 2 were closed or do not have diesel. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
The rail is something I bolted rather than fabricaed, see my gallery. Don't have a fox wing, check kens gallery he does and it like smart, do a search for foxing as there is a recent post about it and the oztent ![]() The £'s can add up but you can always buy a commercial rack for 100squid of eBay, and and an awning/army basha, will do nearly the same thing for a fraction of the cost ![]() |
Puma90man Member Since: 27 Feb 2011 Location: South Africa Posts: 26 ![]() ![]() ![]() |
Nice
TD5_90 Member Since: 02 Apr 2011 Location: Perthshire Posts: 89 ![]() ![]() ![]() |
ok, here goes, what you might be seeing below is my Defender:
