Home > Puma (Tdci) > Brake Fluid Change
rob369
United Kingdom 2013 Defender 90 Puma 2.2 HT Aintree Green
Brake Fluid Change
Hi one and all, can anyone advise as to whether 1 litre of brake fluid should be sufficient for a routine fluid change on my 2.2 90 tdci or should I buy 2. THANKS
Post #642065 5th Aug 2017 6:56pm
bear100
Sorry to hijack the thread Embarassed but when should the fluid be changed? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #642071 5th Aug 2017 7:13pm
rob369
2 years is recommended
Post #642077 5th Aug 2017 7:32pm
bear100
Ohhhh had mine 7 years and it's never been done Shocked 2016 Range Rover Autobiography 4.4 TDV8
Post #642080 5th Aug 2017 7:48pm
williamthedog
It should be enough but get a spare litre. If you dont open it, it will last for a while Thumbs Up
Post #642089 5th Aug 2017 8:13pm
zsd-puma
Brake fluid will last longer than two years. The problem is it absorbs moisure which can boil if you need to brake hard, which then gives you brake fade. You can test it with a moisture tester, a lot of garages just do that these days rather than routinely replace it. Replacing also flushes out some of the muck in there too mind you, so i tend to change it every couple of years.
It should be enough, but the fluid is cheap enough. You don't need any fancy (expensive) DOT5 stuff either, just normal DOT4 will do, it's all Land Rover recomend. Most brake fluid exceeds DOT4 anyway, that's just the minimum standard they put on the bottle, you'd be hard pushed to find anything that only just met DOT4.
Post #642123 5th Aug 2017 10:38pm
Lightningtweeds
Scotland 2008 Defender 90 Puma 2.4 CSW Stornoway Grey
You wont need 1 Litre.
Post #642210 6th Aug 2017 11:31am
I once had my fluid at 4 years because I didn't k is it should be two and no one included it in servicing. Rolling Eyes
I now get it done every two years, I agree on it taking in moisture and when replaced you can ever so slightly tell the difference. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #642217 6th Aug 2017 12:20pm
Lightningtweeds
Brake pipes seem to demand a refresh every Mot?
Post #642253 6th Aug 2017 3:25pm
rob369
Thanks for all the helpful input I will probably buy an extra bottle to be on the safe side and get on with it shortly.
Post #642352 7th Aug 2017 9:40am
lohr500
Hi Rob369,
May be teaching mother to suck eggs, but if you carefully draw off a lot of the old fluid from the master cylinder with a syringe before pouring in the new, you can get away with using less of the new fluid. ( Yorkshireman speaking with deep pockets and short arms Laughing )
Just make sure you don't draw off too much and allow air into the master cylinder, otherwise bleeding can become more of a task.
Changed mine last year when the 110 was 4 years old. Thought it would do the system good to have some fresh fluid pumped through and it was a chance to free off the bleed nipples.
Post #642360 7th Aug 2017 10:38am
zsd-puma
It's not so much about using less fluid, but it certainly means you're not pushing manky stuff through the system when you don't need to. Wink
Post #642456 7th Aug 2017 7:00pm
Merlin
FYI garages just flush the first foot or so out of each wheel. The reasoning is that that is the only bit that air can get to. So to do it professionally, you won't need much.
Merlin
Post #642584 8th Aug 2017 3:28pm
zsd-puma
I think the reasoning is more to do with it being cheaper to only spend 10 minutes doing it. Laughing
Post #642603 8th Aug 2017 5:20pm
rob369
Thanks for the benefit of your experience chaps is helps boost confidence on projects. Cheers!
Post #642718 9th Aug 2017 9:39am
