Home > In Car Electronics > Central locking fault |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17205 |
It could be a high current draw from the OSR actuator. You could unplug that door from the harness (small connector inside the OS 'B' post near where the rubber cable trunk enters from the door) and see if everything works normally with it disconnected, or simply wait to to see if it happens again.
3rd Aug 2017 5:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20114 |
Could be broken wires in the rubber door boots, sounds like a short to me.
NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
3rd Aug 2017 6:09pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1909 |
Had the exact same issue with mine and the very same door it was indeed the wires in the rubber boot they had suffered fatigue and cracked wires inside, a little work cutting ou the old and fitting new (use multi strand)
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
3rd Aug 2017 7:43pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1832 |
Had exactly the same issue last week. Broken wire in the B pillar leading to the OSR door
Click image to enlarge 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
3rd Aug 2017 8:02pm |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
Thanks fellas.
The visible wiring from the pillar to the door looks ok, but I suppose that's no guarantee. How do I look for where a discontinuity could be? Rosco - how did the AA find it buried in the pillar? |
3rd Aug 2017 8:45pm |
The technician (that's the title isn't it?) seemed to have previous experience with the same symptoms on another defender. He asked which door was shut last when we had all got out, and he was bang on the money. To be fair he'd also spent 15 mins plugged into the OBD checking for more obvious reasons first 2007 - Stornoway Grey 90 XS SW - Gone
3rd Aug 2017 9:20pm |
Click image to enlarge So, when I finally had time for a proper look, this practically fell out of the rubber gaiter. Door card removal it is then🙄 |
14th Aug 2017 3:58pm |
Opportunity to fit a bit of dynamat? 2007 - Stornoway Grey 90 XS SW - Gone
14th Aug 2017 4:13pm |
Got round to fixing it. Bought these trim removal pliers - expensive but very easy to use. Attached photo of fir tree clip sockets - some white and some black (including one top left by the lock catch). The piece of rag trick popped off the circlip on the window winder handle.
Once again, thanks to the Forum members for the answers I needed which has saved me lots of money👍 Click image to enlarge Click image to enlarge |
22nd Aug 2017 6:21pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10676 |
They look good pliers, where did you get them from please, many thanks 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
23rd Aug 2017 10:04pm |
Machine Mart. https://www.machinemart.co.uk/p/power-tec-trim-clip-remover/
Did the job very well, but at 21, I'm sure there's cheaper alternatives. |
24th Aug 2017 11:39am |
Many thanks for the link and yes i found the same ones for 6.99 free delivery, just paid for them, thank you again
The link is ebay and sold by clarksontools 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th Aug 2017 9:56pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1372 |
OSR door strikes again!
Went out to go to work this morning, key fob appeared dead and wouldn't unlock the doors. Managed to get in with the key, but the immobiliser wouldn't let the engine run, shut down a second or two after starting. The battery has been a bit lazy recently, needed charging every week, so decided to get a new one. With the new battery fitted nothing worked and alarm & horn sounded when tried to start. Discovered a blown fuse, 20A F9, under the steering column. A quick search on the forum and I found this thread. Unplugged the wiring for the OSR door, locked and unlocked the CDL with the fob, then it started first time! One of the wires was indeed snapped. A job for the weekend, when I've got time. Thanks to all above for getting it going again. |
20th Apr 2021 9:48pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 297 |
Does anyone make uprated door looms?
Just checked Auto Sparks with no joy. |
16th Oct 2021 10:19am |
