Home > In Car Electronics > Central locking fault
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Got back to my Def this afternoon and it didn't respond to the remote. Replaced the key fob battery (got mugged for £5 by a local jeweller for it who was the only shop to sell 2032s nearby) and still no joy. Walked bloody miles too - all with a gammy achilles.
Noticed the LED on the dash wasn't flashing, so assumed it was a shafted battery or suchlike as the whole car was dead. I've never used the door key to gain entry before and the lock was crudded solid and I couldn't get the key all the way in. So I was stuck Thumbs Up
Green Flag guy arrived. De-crudded door lock. Got in. Battery fine.
Fault found to be blown fuse under dash (F9). Changed fuse (20A). All good, but sluggish/inconsistent locking release on the rear offside door mechanism - maybe the cause?
Green Flag dude used his ammeter and found that activating the locking was drawing 8 Amps (which sounds like a lot - is it?). He said it may spike higher, but his tester maybe wasn't 'fast' enough to pick it up? Thought it may be chaffed or broken wiring or, if not, the solenoid?
If it isn't the wiring, do you recommend replacing the locking mechanism/solenoid? How expensive/easy/any tips?
Or do I just bite the bullet and take it to a sparky and bear the cost? (I don't want a fire)
Top tip - de-crud your door locks now and again so your key gets in. I could have sat in the boot I suppose, but would have looked a right tw@t parked outside the vets where it was Laughing
Post #641656 3rd Aug 2017 4:36pm
It could be a high current draw from the OSR actuator. You could unplug that door from the harness (small connector inside the OS 'B' post near where the rubber cable trunk enters from the door) and see if everything works normally with it disconnected, or simply wait to to see if it happens again.
Post #641660 3rd Aug 2017 4:48pm
Could be broken wires in the rubber door boots, sounds like a short to me.
Thumbs Up KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #641667 3rd Aug 2017 5:09pm
bear100
Had the exact same issue with mine and the very same door Shocked it was indeed the wires in the rubber boot they had suffered fatigue and cracked wires inside, a little work cutting ou the old and fitting new (use multi strand)
Thumbs Up Thumbs Up Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #641691 3rd Aug 2017 6:43pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Had exactly the same issue last week. Broken wire in the B pillar leading to the OSR door
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #641694 3rd Aug 2017 7:02pm
Doc P
Thanks fellas.
The visible wiring from the pillar to the door looks ok, but I suppose that's no guarantee.
How do I look for where a discontinuity could be? Rosco - how did the AA find it buried in the pillar?
Post #641707 3rd Aug 2017 7:45pm
Rosco
The technician (that's the title isn't it?) seemed to have previous experience with the same symptoms on another defender. He asked which door was shut last when we had all got out, and he was bang on the money. Thumbs Up To be fair he'd also spent 15 mins plugged into the OBD checking for more obvious reasons first 2007 - Stornoway Grey 90 XS SW - Gone
Post #641724 3rd Aug 2017 8:20pm
Doc P
So, when I finally had time for a proper look, this practically fell out of the rubber gaiter. Door card removal it is then🙄
Post #643877 14th Aug 2017 2:58pm
Rosco
Opportunity to fit a bit of dynamat? 2007 - Stornoway Grey 90 XS SW - Gone
Post #643880 14th Aug 2017 3:13pm
Doc P
Got round to fixing it. Bought these trim removal pliers - expensive but very easy to use. Attached photo of fir tree clip sockets - some white and some black (including one top left by the lock catch). The piece of rag trick popped off the circlip on the window winder handle.
Once again, thanks to the Forum members for the answers I needed which has saved me lots of money👍
Post #645697 22nd Aug 2017 5:21pm
L110CDL
They look good pliers, where did you get them from please, many thanks Thumbs Up Clayton.
Keeper.
Post #645974 23rd Aug 2017 9:04pm
Doc P
Machine Mart. https://www.machinemart.co.uk/p/power-tec-trim-clip-remover/
Did the job very well, but at £21, I'm sure there's cheaper alternatives.
Post #646058 24th Aug 2017 10:39am
L110CDL
Many thanks for the link and yes i found the same ones for £6.99 free delivery, just paid for them, thank you again Wink
The link is ebay and sold by clarksontools Thumbs Up Clayton.
Keeper.
Post #646167 24th Aug 2017 8:56pm
DSC-off
OSR door strikes again!
Went out to go to work this morning, key fob appeared dead and wouldn't unlock the doors.
Managed to get in with the key, but the immobiliser wouldn't let the engine run, shut down a second or two after starting.
The battery has been a bit lazy recently, needed charging every week, so decided to get a new one.
With the new battery fitted nothing worked and alarm & horn sounded when tried to start.
Discovered a blown fuse, 20A F9, under the steering column.
A quick search on the forum and I found this thread.
Unplugged the wiring for the OSR door, locked and unlocked the CDL with the fob, then it started first time!
One of the wires was indeed snapped.
A job for the weekend, when I've got time.
Thanks to all above for getting it going again. Thumbs Up
Post #899237 20th Apr 2021 8:48pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Does anyone make uprated door looms?
Just checked Auto Sparks with no joy.
Post #925914 16th Oct 2021 9:19am
