![]() | Home > Maintenance & Modifications > Clutch switch |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20745 ![]() ![]() |
Anyone? WeWillWin🇬🇧🇺🇸
I have a td5 and my clutch switch was disconected years ago. More power on take off te get up a steep hill.
But as you have a Puma I don't know how it affects you. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 ![]() ![]() ![]() |
Did mine a few months ago, the fitting is a pig to get on and I needed a crows foot spanner... When I loosened it the housing came with it and was then a pain to do back up and not leak, got there eventually though. Had to bleed the clutch after. One of those simple jobs that turns into a couple of hours, but if i'd been aware the housing was coming away at the time I could've saved myself an hour of faffing trying to refit it.
It's all good now though!, think there's some pics in my album? |
Roel - I believe the TD5 and TD4 are different. I think the TD4 has to be replaced or bridged but the TD5 can just be unplugged.
Tobz - Thank-you for the info, that is a bit more than I intended really. I pumped the clutch a few times before setting off today, and no rev on gearchance. So I'm even more sure it's the switch now. There is further information on this, on the TD5 and TD4 one has N/O contacts the other N/C contacts. I cannot remember which off the top of my head. However, I have heard many with TD5's as Roel suggests simply unplug. With a Puma, some replaced, some have bridged the switch with perfect results. It suggests to me the Puma is a N/C switch, the TD5 N/O. I'm curious to hear anybody's solutions to bridging it, and how things went. I know members here have done this. For reference. (Many know this anyway) N/C = Normally Closed switch contacts. N/O Normally Open switch contacts. ![]() ⛽️🛢️⚙️🧰💪 |
Update on this, some of you may be curious....
Clutch switch I did indeed find to be faulty, it appeared to be intermittent and sporadic. And very very annoying giving the drive a feeling of something mechanically wrong when there wasn't. I have not removed the switch or replaced it. (Which could have been done.) Indeed I have disabled it and bypassed it, with no issues in fact with a better drive. The previous issues are now gone and also have better control. I used to get a bit of a lurch and over rev on gear change which made for an awful drive. Especially when colder or in lower gears. The rev to approx 1100 or so rpm when in low range is also gone which I hated, however the anti stall is still 100% operational as is the diff lock light etc etc. If you choose to disable the clutch switch on the Puma you must make sure it's kept a closed circuit. The opposite to a TD5 of which on a TD5 you can just unplug it no problem. A Puma is not quite so simple, but not difficult. I removed the battery negative. (As per normal safety practice to shut everything down.) Removed the clutch switch plug from the switch. Now these plugs are known as Junior Power Timer plugs. (Many thanks to PaulMC for identifying these.) These are avaible for purchase online and in this instance a 2 - pole. Purchase a Male plug with Make pins and seals and fit a wire loop as shown: ![]() Click image to enlarge This simply plugs into the LR harness Female plug, and can be zip tied out of the way. This doesn't damage the harness wiring in any way so no splicing and totally reversible should you wish. The location of the existing clutch switch Male plug, I simply purchased a Female. J.P.T. connector with no pins or seals this time, Silicone sealed the cable entries to prevent ingress and fitted it. See pic: ![]() Click image to enlarge It then tidies the clutch switch area up, so it no longer looks like obviously something has been un-plugged or missing. If you have a fully working clutch switch, it also preserves it in good condition should you wish to reverse to mod. I have not had any MIL or any DTC's doing this, and has made for a better all round drive with better control. In particular in low range. Anti stall us fully operational still in low and high as expected. ![]() ⛽️🛢️⚙️🧰💪 |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1851 ![]() ![]() ![]() |
Thanks Steve,
very useful to know that it disables the rev hand in low range - I like to use low on a difficult trailer reverse into the garage and the 1100 rev is just a little too fast, so your mod will be on the to do list! Cheers keith |
![]() But I was pleased to notice it doesn't at all. I've ran this since early this year for months nowwith zero issues. The J.P.T. Connectors are around �12 I think for both or around that region. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Jonnyfive Member Since: 18 Dec 2016 Location: Devon Posts: 25 ![]() ![]() ![]() |
I really need to do mod, it's driving me nuts when it's playing up.
Steve, what size cable is it please, so I can get the right pins. |
2.5mm IIRC. However I used slightly oversized 3mm2 wire at the time as that was what I had.
There isn't really any load on it to worry much. But I'm pretty sure the pins were 2.5mm. ![]() ⛽️🛢️⚙️🧰💪 |
Thank you Steve
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
Just a little point for Td5 owners, if you unplug the clutch switch on a Td5 it will stop the factory cruise control working
![]() Which is strange as its a N/O switch ![]() ![]() For this reason I'm constantly connecting and disconnecting mine depending on whether I'm going on a long trip or driving locally. I really must wire a relay into the cruise master switch so it disconnects the clutch switch when cruise is off ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Grafty99 - Interesting. A switch definitely sounds like the best solution.
My cruise control still works. If I press the clutch the CC still deactivates as it senses a ref increase and no speed increase. The same as it deactivates when your clutch is worn. My CC is a few switches connected to the ECU so not really factory but using the factory software. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Mine won't activate with the clutch switch disconnected at all. Very odd! 2002 90 Td5 Station Wagon
