Home > Technical > converting to power steering |
Should just be a case of fitting the steering box and engine driven pump with the hoses to connect the two.
I think it took a bit more effort on a Series 3, but on a coil sprung vehicle it should all just bolt on. The only issue you might have is if the military had something else fitted on the engine where the pump usually goes, like a compressor or second alternator etc |
31st Jul 2017 4:41pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Hi Steve, there are a couple of people locally (I'm in Northchurch) that will have the parts, drop me a PM and I'll give you some numbers.
31st Jul 2017 6:53pm |
109+1 Member Since: 29 Jul 2017 Location: Berkhamsted Posts: 4 |
Hi Jeremy will pm you once my post count is correct
5th Aug 2017 3:44pm |
