Home > Td5 > 110 CSW Doors
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
110 CSW Doors
I have a couple of spots of rust appearing on my TD5 110 CSW 2nd Row doors and I want to get them sorted before they get too much worse.
- both have a small area of penetrating rust near the window frame above the door catch. is this weldable? rust is about 1 inch square in both cases.
Post #638528 19th Jul 2017 9:12pm
lightning
I think the door skins are aluminium.
Post #638810 21st Jul 2017 2:52pm
Post '02, the doors are all steel. Darren
Post #638818 21st Jul 2017 3:31pm
bankz5152
The door skins are ali. The door frames are steel. Should be weldable.
Post #638839 21st Jul 2017 5:23pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
I believe the change over wasnt until 2005.......
My 2003 definitely has ali door skins.
Post #638860 21st Jul 2017 7:45pm
Ah, my mistake. I thought they were introduced at the same time as the steel rear door. Darren
Post #638872 21st Jul 2017 8:35pm
mactheknife
Thanks for all the responses, been away for a few days so not had chance to catch up.
Its a 2004 model. So all steel then.
Next job is to find a welder near Wells.
Post #639307 23rd Jul 2017 10:15pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
One way to find out if they're all steel, use a magnet near the center of the door away from the frame. The all steel doors should be have pressed steel frames, so have the rounded corners, and fitted to 2005 vehicles onwards. Ali skinned doors have welded frames, you can see the welds in the corners.
Post #639346 24th Jul 2017 7:32am
bankz5152
No. Steel frame ali door skins. I believe the change was 2007 with the Pumas. Never seen a standard TD5 with one peice doors.
Post #639367 24th Jul 2017 12:23pm
My '05 TD5 had the newer all steel doors, which is what led to my earlier comment. Darren
Post #639368 24th Jul 2017 12:32pm
Martin
Site Admin
Late Td5s have the "Puma" side doors.
If the inside of the top of the door is in one-piece with rounded corners then it's a "Puma" door. If it is welded from 3 pieces, with angular corners it is the earlier fabricated frame, alloy-skinned door.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #639369 24th Jul 2017 12:33pm
The pedant in me can't help but think that Pumas had late TD5 doors Twisted Evil Darren
Post #639370 24th Jul 2017 12:35pm
Martin
Site Admin
Anorak Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #639388 24th Jul 2017 2:29pm
mactheknife
The doors are welded in three parts at the top, so steel with ally skins then!
Post #639764 25th Jul 2017 9:59pm
lightning
Which doors are better, the "Puma" rounded corner ones or the earlier square corner ones?
My 2005 TD5 110 has the later type.
Post #640693 30th Jul 2017 12:02pm
