Home > Wheels & Tyres > Picked up a screw in tyre
adminkatana
United Kingdom 2015 Defender 90 Puma 2.2 CSW Keswick Green
I noticed a screw in my rear tyre this afternoon. Haven't driven for two days, the tyre pressure is the same as when last checked two weeks ago so appears to be unaffected.
Do you think I have gotten away with it? Best to leave in place or try and remove?
Appreciate your advice! Thanks.
Post #637674 15th Jul 2017 4:26pm
grafty99
Its a really tricky one. If it ain't broke don't fix it. But it is also an accident waiting to happen. One thing is for sure and that is that a tyre shop won't repair it as its too close too the edge Crying or Very sad 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #637676 15th Jul 2017 4:41pm
I'd be looking mostly at exactly where the tip of the screw has gone.
Looking at it from what I can see, it looks like you have JUST got away with it.
MT / AT tyre's have thick sidewalls and banding / cords, so I very very much doubt there is any air leakage.
If you'd have had road biased tyre's I'm pretty sure you'd have had a flat and a wrote off tyre. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #637677 15th Jul 2017 4:44pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
I bought a spare wheel and tyre from Blanchards (deals in ex MOD stuff) and found a bullet casing embedded at roughly 45 degrees. My initial thought was that the tyre was definitely gone so I let the air out and yanked it out with a pair of mole grips. Casing came out, was nearly 2 inches in length and left a good sized hole in the tyre. Convinced it had gone through, I pumped the tyre back up and was amazed to find it held pressure!
However, judging by the pictures, the screw looks at a much more shallow angle so as above, you might be OK and hence I would probably be inclined to leave it. Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #637720 15th Jul 2017 8:14pm
adminkatana
That's great thanks, appreciate all your advice.
I'm going to monitor the tyre pressure and keep a good eye on it. Hopefully it'll be ok. Just wanted to make sure it didn't look too dodgy in other peoples opinions! A bullet casing would be pretty impressive though Smile
Post #637723 15th Jul 2017 8:54pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
That's through the tread only! My advice would be to remove the screw asap before movement and wear forces it into the carcass. Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #637728 15th Jul 2017 9:09pm
^^^ What he said, you've been lucky! Remove it asap.
Post #637731 15th Jul 2017 9:18pm
On a different note have you been green laning lately at all? TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #637738 15th Jul 2017 9:50pm
adminkatana
Just unscrewed the screw (only way to get it out) and thankfully when looking at my original photo and a photo of the screw held up next to the tyre I can see from the dents on the screw pattern that just the end nib was poking into the tread.
Tyre pressure is still exactly as before, will keep an eye on it just in case! Appreciate all your help!
Not been green lining recently I'm afraid, just normal road driving, nowhere I'd expect to pick up a nail more than usual either.
Post #637741 15th Jul 2017 10:13pm
