![]() | Home > Wheels & Tyres > Picked up a screw in tyre |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Its a really tricky one. If it ain't broke don't fix it. But it is also an accident waiting to happen. One thing is for sure and that is that a tyre shop won't repair it as its too close too the edge
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20676 ![]() ![]() |
I'd be looking mostly at exactly where the tip of the screw has gone.
Looking at it from what I can see, it looks like you have JUST got away with it. MT / AT tyre's have thick sidewalls and banding / cords, so I very very much doubt there is any air leakage. If you'd have had road biased tyre's I'm pretty sure you'd have had a flat and a wrote off tyre. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 513 ![]() ![]() ![]() |
I bought a spare wheel and tyre from Blanchards (deals in ex MOD stuff) and found a bullet casing embedded at roughly 45 degrees. My initial thought was that the tyre was definitely gone so I let the air out and yanked it out with a pair of mole grips. Casing came out, was nearly 2 inches in length and left a good sized hole in the tyre. Convinced it had gone through, I pumped the tyre back up and was amazed to find it held pressure!
However, judging by the pictures, the screw looks at a much more shallow angle so as above, you might be OK and hence I would probably be inclined to leave it. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
adminkatana Member Since: 11 Apr 2016 Location: Sussex Posts: 31 ![]() ![]() ![]() |
That's great thanks, appreciate all your advice.
I'm going to monitor the tyre pressure and keep a good eye on it. Hopefully it'll be ok. Just wanted to make sure it didn't look too dodgy in other peoples opinions! A bullet casing would be pretty impressive though ![]() |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
That's through the tread only! My advice would be to remove the screw asap before movement and wear forces it into the carcass. Formerly mao99999
16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17643 ![]() ![]() ![]() |
^^^ What he said, you've been lucky! Remove it asap.
On a different note have you been green laning lately at all? TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Just unscrewed the screw (only way to get it out) and thankfully when looking at my original photo and a photo of the screw held up next to the tyre I can see from the dents on the screw pattern that just the end nib was poking into the tread.
![]() Click image to enlarge Tyre pressure is still exactly as before, will keep an eye on it just in case! Appreciate all your help! Not been green lining recently I'm afraid, just normal road driving, nowhere I'd expect to pick up a nail more than usual either. |
