Home > Maintenance & Modifications > Rear seats in a Puma 90 soft top conversion. |
It can be done but involves cutting the arches to install shaped panels and the installation of various brackets for the seats and seat belts to attach to. There's been several threads about it on here, which I'm sure a search will turn up. Darren
17th Jun 2017 8:41pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7890 |
Probably not the best thread but see pj2106 post on pg1, shows an idea of work involved.
http://www.defender2.net/forum/topic53804....at+install James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
17th Jun 2017 9:44pm |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 |
Seat belt mounting on a soft top could be tricky?
18th Jun 2017 6:46am |
How were seat belts fitted in the SVX, off the SD roll cage I assume? James
18th Jun 2017 7:41am |
Seat belts top mounts are a good point. Maybe a hood stick alternative from Purely Metal would provide a suitably strong anchor point. Darren
110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 18th Jun 2017 11:55am. Edited 1 time in total |
18th Jun 2017 9:14am |
madfrankie Member Since: 10 Oct 2016 Location: Hertfordshire Posts: 356 |
There are no rear seats in the SVX soft top.
CSK do a replacement panel to fit in the wheel arch. They can provide the fitting service or just the panel. I did my own and apart from the worry about cutting your arches it isn't hard. Are pictures on my build thread that I can send if you want them. "Of Course, Of course, I ain't asking . I'm telling!!" |
18th Jun 2017 10:03am |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
Thanks for the info guys, especially the link to the rear seat installation thread.
I shall have to give this some thought! Unfortunately isn't a simple bolt in solution Chris 2010 Defender 110 Station Wagon, Santorini Black. |
18th Jun 2017 8:02pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
Is it a svx or a soft top conversion as most conversions have ability to fit seat belts in back frame to use the puma seats 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
18th Jun 2017 8:10pm |
It's a 2010 Puma truck cab conversion, problem is the square wheel boxes, the upper seat belt mount isn't a problem, it can be mounted to the rear frame. 2010 Defender 110 Station Wagon, Santorini Black.
19th Jun 2017 5:02pm |
