Home > Td5 > Added bonnet struts with home made brackets
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
So spent a couple hours yesterday adding universal struts to the bonnet. No more retro 1940s bonnet stay in the way all the time. Thought I'd share some details. Used existing fender bolts and only drilled into the bonnet to mount the ball posts. I picked up four of these struts at a surplus shop here in Ottawa for $10 (�7). Brackets are just bent aluminum 3/16 x2 inch bar.
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #630389 10th Jun 2017 4:42pm
Sulisuli
Nice work, will add that to my list of things to do Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #630408 10th Jun 2017 5:27pm
gilarion
Is that some sort of sound deadening spray on the underside of your bonnet, and if so does it make a difference. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #630416 10th Jun 2017 6:18pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Ha! i spotted that too and was about to ask the same question Thumbs Up
Post #630419 10th Jun 2017 6:34pm
rockster57
I see your original bonnet stay is still fitted. Will that be coming off or do you foresee circumstances where you will still use it?
Post #630422 10th Jun 2017 6:36pm
4RF RDS
I LINEX'd it.. very helpful to stop innocuous dents from forming on the bonnet. As for sound, no real noticeability there. The rubber seal on the bonnet edge did a LOT to reduce any noise from the engine bay. No leaking sound from around the edges, also the Td5 is pretty quiet compared to Tdi's and NA Diesels. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #630430 10th Jun 2017 7:27pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Nice!
Princess Auto struts?
I've just been doing the install of my Webasto under the hood on my 2003 and see you have one installed. Did you bother with the one way valve in the 18mm inlet hose for when the Webasto is not running?
Also, did you find any difference in heater airflow with the snow cowl installed during the winter?
Patrick
Post #630571 11th Jun 2017 4:47pm
4RF RDS
Om
No difference with the airflow and snow cowl in place has been noticed . I also have the Landreziegr digital fan speed control installed which I did notice increased full speed quite a bit. As for the Wabasto it came from the factory with it intsalled so cannot comment with great alacrity. Shocked
Princess Auto is a national store for farmers, hydraulic stuff, surplus and all kinds of great off road and recovery gear at great prices. Also tons of trailer and auto electric parts, welding fabrication and tools. Bow down
https://www.princessauto.com/en/ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #630573 11th Jun 2017 5:22pm
