Home > Technical > Numberplate Light Plinth
hank
What is the point of it? Is it just a spacer? Given that the light only needs to be spaced out the thickness of a numberplate and the 'lens' of the light is already spaced proud of the plate by the light base itself, what is wrong with mounting the light directly to the body?
I am swapping to an LED numberplate light for info
Post #629649 7th Jun 2017 12:31pm
zsd-puma
I can't really think of a reason for it to be there in the UK.
Perhaps in some countries where they don't have the large square plates and use small rectangular ones (US, Japan for example) it's needed to throw the light further down the body. Certainly in the UK i don't see any reason you couldn't lose the spacer.
Post #629652 7th Jun 2017 12:42pm
Stacey007
Handy for fitting a camera in Smile
Post #629654 7th Jun 2017 1:01pm
JOW240725
Interesting question, often wondered why it sticks out so far. James
Instagram @suffolk_rovers
Post #629666 7th Jun 2017 1:49pm
mk1collector
I took my spacer off years ago and it still all works fine and the plate is still lit up. Ray
My build thread
Post #629673 7th Jun 2017 2:52pm
You can do without it completely if you wanted. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #629693 7th Jun 2017 4:34pm
V8GPC
When I fitted an LED version the cable exit was in a different place to the hole in the body.
I turned the plinth around; drilled a new hole to line up with the LED and then the cable had a nice void to realign with the body... so came in useful in the end. Exclamation
Post #629719 7th Jun 2017 5:58pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Really handy for fitting a rear view camera in Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #629809 7th Jun 2017 10:50pm
