![]() | Home > Technical > Numberplate Light Plinth |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
I can't really think of a reason for it to be there in the UK.
Perhaps in some countries where they don't have the large square plates and use small rectangular ones (US, Japan for example) it's needed to throw the light further down the body. Certainly in the UK i don't see any reason you couldn't lose the spacer. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3803 ![]() ![]() |
Handy for fitting a camera in
![]() ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Interesting question, often wondered why it sticks out so far. James
I took my spacer off years ago and it still all works fine and the plate is still lit up. Ray
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20637 ![]() ![]() |
You can do without it completely if you wanted. TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
When I fitted an LED version the cable exit was in a different place to the hole in the body.
I turned the plinth around; drilled a new hole to line up with the LED and then the cable had a nice void to realign with the body... so came in useful in the end. ![]() |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
Really handy for fitting a rear view camera in
![]() The longer I live..... The better I was! |
