![]() | Home > Td5 > MAF? Best ones? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Genuine, Bosh or Hella in that order.
There are a lot of cheap aftermarket ones about (like everything else) And they can be hit and miss. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
When I was looking, the cheapest genuine MAF I found was island4x4 TD5 Defender 90
Discovery 3 HSE |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Siemens/VDO is the original supplier of these, innit?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
Bosch is Genuine. 99.9% sure on that, the same goes for the MAP. You may as well sort both out. 👍🏻 TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Hmm. Not on a Td5. The genuine one I replaced with a VDO one were absolutely identical.
*EDITED* Martin is correct ref TD5.
I was thinking Puma. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Yep, VDO is genuine on TD5 80" 80" 86" 88" 90"
MAF - VDO
MAP - Bosch TD5 Defender 90 Discovery 3 HSE |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
I have a similar set up to yourself and was thinking when mine goes down i would go down the route and the uprated MAF and MAP sensors, Tuners seem to be using these now instead of the boxes the mask the higher pressures and air flow. But I am not sure if IRB do them. Might be worth asking Ian if he does.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88β 2A 200tdi 2002 110 Hardtop |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
I assume since you have a boost box youre running around 22 - 24psi boost? At that power level youre going to have MAF issues regardless of brand. For normal driving around town i leave it plugged in, off road or having fun i unplug it.
Afaik there isnt an uprated MAF unit available but there are "tuning boxes" for the MAF which allow you to adjust the reading it sends back to the ECU. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6133 ![]() ![]() ![]() |
Just ordered a new MAF form island4x4 (i've had an account with them for years)
As said above, they were the cheapest.... £71.20 delivered, Cheapest I could find for a genuine VDO on fleabay was about £83 ish. Thanks again all. ![]() |
Rusty380 Member Since: 20 Jun 2017 Location: Nottingham Posts: 81 ![]() ![]() |
Is there no way to completely scrap the MAF on these and run with the MAP sensor, or are the ECU's and any mappers not advanced down that line yet?
I got rid of the MAF on my 99 Mitsubishi Evo and it ran speed density instead on a MAP sensor. Sorry if there is an obvious reason why not, i'm learning ![]() |
A td5 runs OK without a MAF
It runs better with a well working MAF and it runs worse with a bad MAF. My experience is that the difference between a bad MAF and No MAF is bigger then the diffeence between No MAF and a Good MAF. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I found with the MAF unplugged it smoked a lot, especially off boost.
Fitted the new one today. Just need to take it for a bimble too see how it performs now. |
