Home > Td5 > MAF? Best ones?
MAF? Best ones?
My MAF is on its way out.... 110 has been sluggish for a while from pulling away and putting your foot down; once on boost it flies.
just unplugged the MAF and bam! away she goes much better.
I've got an IRB 190bhp tune, VGT turbo, boost box (and snorkel), any good recommendations for a decent aftermarket MAF? or just go genuine?
Post #628185 1st Jun 2017 12:51pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Genuine, Bosh or Hella in that order.
There are a lot of cheap aftermarket ones about (like everything else)
And they can be hit and miss. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #628188 1st Jun 2017 12:58pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
When I was looking, the cheapest genuine MAF I found was island4x4 TD5 Defender 90
Discovery 3 HSE
Post #628200 1st Jun 2017 1:51pm
Martin
Site Admin
Siemens/VDO is the original supplier of these, innit?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #628205 1st Jun 2017 2:04pm
Bosch is Genuine. 99.9% sure on that, the same goes for the MAP. You may as well sort both out. 👍🏻 TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #628206 1st Jun 2017 2:04pm
Martin
Site Admin
Hmm. Not on a Td5. The genuine one I replaced with a VDO one were absolutely identical.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #628207 1st Jun 2017 2:05pm
*EDITED* Martin is correct ref TD5.
I was thinking Puma. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #628208 1st Jun 2017 2:06pm
ian series 1
Yep, VDO is genuine on TD5 80" 80" 86" 88" 90"
Post #628218 1st Jun 2017 2:50pm
huffhuff
MAF - VDO
MAP - Bosch TD5 Defender 90
Discovery 3 HSE
Post #628224 1st Jun 2017 3:19pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I have a similar set up to yourself and was thinking when mine goes down i would go down the route and the uprated MAF and MAP sensors, Tuners seem to be using these now instead of the boxes the mask the higher pressures and air flow. But I am not sure if IRB do them. Might be worth asking Ian if he does.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #628429 2nd Jun 2017 11:27am
bankz5152
I assume since you have a boost box youre running around 22 - 24psi boost? At that power level youre going to have MAF issues regardless of brand. For normal driving around town i leave it plugged in, off road or having fun i unplug it.
Afaik there isnt an uprated MAF unit available but there are "tuning boxes" for the MAF which allow you to adjust the reading it sends back to the ECU.
Post #628455 2nd Jun 2017 12:35pm
Just ordered a new MAF form island4x4 (i've had an account with them for years)
As said above, they were the cheapest.... £71.20 delivered, Cheapest I could find for a genuine VDO on fleabay was about £83 ish.
Thanks again all. Thumbs Up
Post #634469 29th Jun 2017 6:21pm
Rusty380
Is there no way to completely scrap the MAF on these and run with the MAP sensor, or are the ECU's and any mappers not advanced down that line yet?
I got rid of the MAF on my 99 Mitsubishi Evo and it ran speed density instead on a MAP sensor.
Sorry if there is an obvious reason why not, i'm learning Laughing
Post #634574 30th Jun 2017 6:53am
roel
A td5 runs OK without a MAF
It runs better with a well working MAF and it runs worse with a bad MAF. My experience is that the difference between a bad MAF and No MAF is bigger then the diffeence between No MAF and a Good MAF. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #635380 3rd Jul 2017 7:07pm
I found with the MAF unplugged it smoked a lot, especially off boost.
Fitted the new one today. Just need to take it for a bimble too see how it performs now.
Post #635657 4th Jul 2017 9:05pm
