Home > Technical > Wheel wobble...
Profyaffle
Wheel wobble...
I noticed my steering felt lumpy yesterday. I have had a search on the internet and have sprayed WD40 on the steering UJ's and then jacked up the front axle and turned the steering wheel to work it in. Whilst the the wheels were up I gave them a wobble. The drivers side has play at 9 and 3 o'clock but none at 12 and 6. Could this be a wheel bearing? I've recently had the swivel topped up with grease as it did have a leak but thats cured itself. 1993 200Tdi Defender 90
Post #626969 26th May 2017 10:45am
dorsetsmith
Post #626994 26th May 2017 12:12pm
Profyaffle
Thanks Dorsetsmith, I have watched that and how to change the bearing.. I haven't got an assistant.. I will try it again at a later date.... 1993 200Tdi Defender 90
Post #626995 26th May 2017 12:17pm
agentmulder
Kuwait
If you're referring to needing someone to put their foot on the brakes, just use a bit of timber wedged against the seat box ...
Thumbs Up
You can put a shoe on it if slips Laughing Solved the bowel problem, working on the consonants...
Post #627149 26th May 2017 10:28pm
