Home > Technical > Wheel wobble... |
26th May 2017 12:12pm |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
Thanks Dorsetsmith, I have watched that and how to change the bearing.. I haven't got an assistant.. I will try it again at a later date.... 1993 200Tdi Defender 90
26th May 2017 12:17pm |
If you're referring to needing someone to put their foot on the brakes, just use a bit of timber wedged against the seat box ...
You can put a shoe on it if slips Solved the bowel problem, working on the consonants... |
26th May 2017 10:28pm |
