Home > Maintenance & Modifications > Soft A bar fitting |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 |
Edit: I've read the other thread on here about this, but I don't think it answers my question...But having looked at another site, with an LRM guide to fitting, I'm confused, as my bracket that wraps around the bumper doesn't have a nut stuck to it like they do here
https://www.makitauk.com/pam/custom/files/LRM-PaddedBar.pdf 1998 110 300Tdi White Hard Top |
25th May 2017 10:02pm |
You should bolt through the a bar into the bracket that wraps around the bumper which then bolts to the chassis. Ray
25th May 2017 11:06pm |
Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142 |
Mine didn't come with brackets either, looked into some but decided in the end to just hex or tex (can never remember which) bolt through the fixing panel at the bottom in to the bumper, seems solid enough, been on for nearly a year with no troubles
Also I modified the lower part to wrap around the bumper as it sat a long way from the grille Click image to enlarge Click image to enlarge |
26th May 2017 5:56am |
I did consider this too. Thanks Matt, I'll probably give this ago. 1998 110 300Tdi White Hard Top
26th May 2017 12:04pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Do the proper instructions help?
https://topix.landrover.jlrext.com/topix/c...oupId=1665 (bolts from back version) https://topix.landrover.jlrext.com/topix/c...oupId=1665 (bolt through front version) 1988 90 Td5 NAS soft top 2015 D90 XS SW |
26th May 2017 12:10pm |
Ah ok thanks Martin.
I didn't realise there were two different fitting kits available. I have a bull bar with a hole for your first link's fitting method VPLPP0060, but the brackets for the second link's method VUB501720. Guess I'll contact the supplier, and see if they can exchange the brackets, if not I'll try Matt's method! 1998 110 300Tdi White Hard Top |
26th May 2017 8:04pm |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 148 |
For info my brackets were shot with rust and after much hunting I couldn't find any online or anywhere so I took the rusty ones to my local engineering firm who made two up for me. I can check with them on Tuesday whether they still have the measurements stored on the profile cutter if this would be of interest. They cost about £100 mind you but far more economical than a new a bar which at £500 was a non starter. Pics below, cheers Andy
Click image to enlarge Click image to enlarge Click image to enlarge |
26th May 2017 8:40pm |
