![]() | Home > Puma (Tdci) > which battery to go for? |
StuLandy Member Since: 28 Jul 2012 Location: Here, there and Everywhere!! Posts: 43 ![]() ![]() |
My Batteries laboring a little now after 10 years, anything different to get other than whats been suggested?
Cheers Stu |
mees Member Since: 04 Mar 2011 Location: sdijk Posts: 38 ![]() ![]() ![]() |
Merry Chrismas everybody
Which battery should I take? Cannot decide between below 3 options. Varta LFD90 (90ah) varta blue dynamic G3 (95ah) Varta silver dynamic H3 (100ah) Car is used occasionally but always on Ctek charger when not used |
You can't go wrong with any of those three. When my factory Varta battery was past its best after almost 9 years, dealer replaced it by the same which essentially is a LFD90. The blue dynamic you mention is not much different, also a wet cell battery, but the silver dynamic is a AGM battery. More expensive, and for normal use not really required. But you can't go wrong with any of those three.
Dus gooi een muntje op zou ik zeggen. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Bedankt Eric
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
VARTA Professional Dual Purpose AGM L95 - 840 095 085
![]() https://www.varta-automotive.com/en-gb/pro...40-095-085 - 95Ah - 850 A - Width : 175 mm - Length : 353 mm - Height : 190 mm ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Zim Member Since: 25 Jul 2013 Location: Small Village, south side of Leicester Posts: 86 ![]() ![]() ![]() |
Ditto on the CTEK charger - my Landie is only used circa once every ten days - I started having issues with the battery running down until I bought one of these. Depending on the charger you get, you get different couplings, one you can permanently wire up to your battery which has a connector - this connector plugs into the corresponding connector on the charger wire. It saves you on having to take the seat apart every time you want to get the charger on! 2007 Defender 90 XS 2022 Defender D300 HSE X-Dynamic |
