![]() | Home > In Car Electronics > WIPAC LED relay, Dash Tell Tale, and Trailer light woes... |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4252 ![]() ![]() ![]() |
Mine is a Puma, but assume it is all the same. I had the RDX relay, but it failed within a few weeks. I couldn't wait while RDX messed about "testing" it to see if they agreed that it was broken so I just bought a Britpart LED one. I know, I know, but a man needs working indicators and my local place had one in stock!
The Britpart one has been pretty much perfect. It works correctly with no trailer connected, I.e, the trailer dash lamp never illuminates. With a trailer connected that has incandescent lights, it flashes the trailer dash lamp with the indicators as it should. With a trailer which has LED lamps, the indicators work fine but I don't get the trailer dash lamp, presumably not enough current to detect the trailer, which I expected to be the case. 2007 110 TDCi Station Wagon XS |
Al_Brown Member Since: 13 Apr 2017 Location: PLYMOUTH Posts: 16 ![]() ![]() ![]() |
Thanks bluest.
I've gone and ordered the RDX relay anyway! I'm concerned about finding all the earthing points now and getting everything sorted within the loom |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Mine need the RDX relay and a replacement dashboard lamp with resistance built into it to stop the opposite side lights coming on when you indicate.
Bolt on bits sell both but only seem to sell the dashboard lamp once you phone them to say you have a problem. 1995 Defender 110 CSW 1971 SIIA Lightweight |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20694 ![]() ![]() |
I've had the RDX one for a long time now and has been faultless, I'd imagine you had a duff one.
![]() There should be one info on here regarding earth points and headers, there are quite a few. Not having an operational dash light for trailer towing or buzzer is not legal I believe. If fitted it must be working, One or the other. TheThunderRollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
You need the Led telltale dash light with resister
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
In practice this is the case on a Defender. Although on other more advanced cars (like a late Range Rover for example), the in built dash warning messages for bulb failure are acceptable. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4799 ![]() ![]() ![]() |
Does your warning panel have one warning light for both indicator directions? If so this is where the problem is. To solve it you either need a slightly later warning panel with separate warning lights for each direction or two diodes behind to stop the voltage being transferred to the other side
![]() The trailer tell tale sensitivity is adjusted by the pot resistor on the top of the wipac resistor ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Here is a thread with a fix
![]() http://www.defender2.net/forum/topic51327....or+problem 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thanks for the useful info! I only have one indicator tell tale on the dash, I didn't know there was a two lamp variant! Anyone got one for sale!!!! ![]() The resistor on the WIPAC relay does the square root of F all.... I've remade all 4 corner earths from the loom, the TX box earth is good and the bulkhead earth under the bonnet is good too, but I've still got a trickle voltage through the LED indicators on the opposite side! |
The thread I linked says that bolt on bits make a indicator warning lamp that solves the problem
Thanks Grafty 👍🏻
![]() So in summary: 1. LED lights can cause issues 2. Dash tell tale can link the opposite side indicators and allow them to flash. This can be fixed with a pair of diodes as per another thread, or the bolt on bits Led with resistor dash lamp. Or a separate dash tell tale for individual side indicators on later Defender variants. 3. The WIPAC relay did NOTHING for my Landy, the RDX one has cured the trailer light issues and the resistor works correctly, however the dash indicator tell tale still needs the above mod. 4. Remaking all the earths still did not cure the initial problem despite the theory suggesting otherwise. Hope that helps someone in future! And thanks for the advice chaps! |
Did a bit more reading on the dash tell tale issue... the quote below is from another forum:
...am still trying to figure out a way to get the dash light to work for both sides i A bi-polar LED will get around your problem. http://www.rapidonline.com/electronic-comp...-led-29359 Alternatively fit a full wave rectifier to the LED. Either way the LED will illuminate regardless of polarity. So... Has anyone fitted a bipolar LED ? Seems like a very elegant solution? |
