Home > Technical > Interior Light Mounting
This might turn out to be a stupid question but can anybody tell me if the backing plates for the later interior lights are fixed to the underside of the central roof rib or are just clamped to the headlining?
The backing plate has what looks like a very obvious mounting hole in the middle, just visible under the tape in the picture below, but if it were used it looks like it would make it difficult to use the spade connection for earth just below. Perhaps screwing it to the roof would provide a suitable earth meaning that a separate cable wouldn't be required? The older style interior lights did just clamp to the headlining Confused
 Darren
Post #623602 12th May 2017 11:54am
dorsetsmith
Just clamped to the headlining?
if you using late type interior light earth go the back plate with spade connection
Post #623612 12th May 2017 12:19pm
The later type is indeed clamped and the back plate is earthed. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #623620 12th May 2017 12:39pm
madfrankie
England 2007 Defender 90 Puma 2.4 SW Stornoway Grey
I clamped it to roof lining and then screwed it to roof strut.
lifted my sagging lining well.
Just remember to remove the 10v fuse for interior lights and stereo first as the slightest bridge whilst fixing it will fuse it. "Of Course, Of course, I ain't asking . I'm telling!!"
Post #623622 12th May 2017 12:45pm
Brilliant, thank you chaps Cool Darren
Post #623624 12th May 2017 12:56pm
