Home > Technical > 2.4 Puma security / cut off / immobiliser
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Hi all
Recently purchased so looking for recommendations for what and how to install a hidden or more obvious security switch.
PM messages probably best... I know there's been a few similar threads before.
I think there's a few issues with simply cutting off the fuel pump etc as the engine shouldn't be run dry but also will be a pain to prime again- stand to be corrected though!
Thanks.
Post #619285 24th Apr 2017 8:54pm
The biggest issue you'll have "cutting off the fuel pump" on a 2.4 Puma is the fact that it's a mechanical pump bolted to the engine!
Post #619291 24th Apr 2017 9:00pm
stuart123
Eek! Shows how little I know. Shocked
Thought mechanical were a thing of the past... the old 2.25 lightweight I've got has one but assumed newer were electrical!!
Post #619298 24th Apr 2017 9:13pm
Td5 is electric, 2.4 is mechanical, 2.2 has an electric lift pump and mechanical hp pump.
Post #619306 24th Apr 2017 9:28pm
zsd-puma
You could fit a manual fuel tap somewhere in the line from the tank to the pump. It'll start but cut out shortly afterwards.
Post #619321 25th Apr 2017 12:13am
stuart123
Thanks. Any other electrical immobiliser suggestions?
Post #619355 25th Apr 2017 8:00am
X4SKP
Hello stuart123
The first question is to Immobilise what... Question
Many say 'Battery' but this may (almost certainly will) be needed when the Vehicle is 'Secured'.
ECU may be possible, PM route is best if someone knows (really knows... how to do this Cool).
Here are two Electrical Immobiliser approaches... To prevent the operation of the Starter Motor
Therefore maintaining the Puma Alarm / ECU / Central Locking / Permanent Live feeds (to possible Tracker)
1. Isolation Switch fitted to interrupt the Main 12V (high Amps) Feed to the Starter Motor
Example Durite 0-605-20 fitted in chosen location
2 Removable keys
ON and OFF positions.
10mm Terminal Studs.
100A @ 24V, 500A for 5 Secs.
2. Isolation Switch to interrupt the S Terminal (Trigger) 12V (low Amps) Feed to the Starter Motor
Under Drivers Seat, identify the Starter Relay (No.3)
At this Relay identify the Trigger Wire (2.5mm2 Brown / Green Wire
Interrupt this and fit a Switch / 12V (low Amp) in chosen location.
C0151-87 NR 2.5D Brown / Green Wire
Good Luck SKIP
Post #619375 25th Apr 2017 9:43am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I like that idea Skip, fairly simple to execute too. Thanks for the detail. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #619394 25th Apr 2017 11:50am
X4SKP
Bigger Picture... Puma Defender (generally should be this)
 SKIP
Post #619412 25th Apr 2017 1:52pm
stuart123
Thanks all, much appreciated.
Post #619644 26th Apr 2017 1:08pm
Gurmot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I'm interested in this for my 2.4 Puma also and have found a lack of discussion online for obvious reasons.
I like the idea of interrupting the low power starter circuit but can't the vehicle simply be bump started?
How are the 2.4's stopped when the ignition is switched off and can this circuit be used? I've thought about interrupting power to injectors but need to think of a way to doing this without showing signs of mods which could lead a thief to cause.
The other thing I've been thinking about is to add a voltage to where it shouldn't be (rather than to interrupt a voltage from getting to where it should be). For example, make the injectors live permanently, to interfere with fuelling and stop it from running if an attempt is made to start without removing the supply fed from a hidden switch.
It looks like the modern thief is well able to bypass normal security measures and get ecu's to tell the vehicle to start and perhaps some alternative thinking may make it harder for them?
Post #619789 26th Apr 2017 9:42pm
zsd-puma
just disable the feed to the engine ECU. It's probably better than disabling the starter, as if they're cranking away with the starter it makes noise.
Plenty of places to hide the switch.
Post #619799 26th Apr 2017 9:51pm
stuart123
Post #620002 27th Apr 2017 7:47pm
stuart123
Where is this feed?
Post #620003 27th Apr 2017 7:48pm
zsd-puma
It's a loose inline fuse bound up in the wiring harness under the drivers seat i believe.
Post #620012 27th Apr 2017 8:23pm
