Home > Technical > 2.4 Puma security / cut off / immobiliser |
stuart123 Member Since: 03 Apr 2017 Location: Manchester Posts: 207 |
Ah, I saw that!
If I try disconnecting it and cranking the engine, what should happen? |
27th Apr 2017 8:53pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Pardon my lack of sparky knowledge....do you have a legend for the diagrams such as wire size?as i can guess what the numbers and letters mean but im not sure! |
28th Apr 2017 6:19am |
key to reading the diagrams
Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 28th Apr 2017 7:11am. Edited 2 times in total |
28th Apr 2017 6:56am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
I've never tried this but I think it is most likely that the engine won't crank, since the starter circuit is enabled by the ECU. It is however possible that the starter circuit is enabled until inhibited by the ECU after engine start, in which casse it would crank but not fire. |
28th Apr 2017 7:02am |
In the UK that won't stop a determined serial Defender thief since he (or she) will most likely bring a 'generic' ECU with the security features disabled to plug in in place of the vehicle's own ECU anyway. It's a quick way to get round the immobiliser.
That is much more likely to be effective! |
28th Apr 2017 7:04am |
Gurmot Member Since: 01 Apr 2016 Location: Somerset Posts: 36 |
The thief with a generic ECU is the reason I am looking at putting a voltage where it shouldn't be rather than cutting a voltage from where it should be (as with a kill switch). For example, putting a permanent voltage across the injectors so they won't pulse, would be hard to find if spliced in carefully.
Edit. If the injector is fired by a ground pulse (permanent +12 feed) then a switch putting a constant ground across all pulse connections is what I am talking about. Hard to spot and not quick to overcome. |
28th Apr 2017 10:04am |
