![]() | Home > Maintenance & Modifications > MAF & MAP Torque for fixings |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I will look on the invoice on Monday, bear in mind we get -20% at our local Ford dealer.
![]() Wanted, Forward Control Anything considered. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 ![]() ![]() |
Cheers, it's 4 pin with right angle style.
It's not the later type with an aero dynamic style. Will report back when I hear from Dan. ![]() Big Brother is Watching. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
A little update on this after a week or so.
After cleaning both sensors all has been good and performance is back to full power. ![]() No issues at all and the bridged clutch switch has thrown up zero issues and makes for a better drive. I've heard back from Dan @ Duckworth parts ref genuine prices. I more or less got it bang on correct: MAP LR022164 £115.48inc vat MAF MHK501040 £109.00inc vat ![]() You can get these parts from the actual OE. Manufacturer for around £65 total for both. ![]() ![]() Big Brother is Watching. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
Steve, excellent thread you've started here
![]() Where is the best place to buy these from assuming the correct parts? Do you have any links? Many thanks Steve |
**EDITED** Play Stupid Games, Win Stupid Prizes.
^^Much appreciated
Well, in the end I didn't replace as of yet anyway. But the cleaning did the world of good! Performance is tip top again and running sweet. My guess is the gunked MAP was the main culprit. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª Last edited by custom90 on 17th May 2019 10:01pm. Edited 2 times in total |
Doing this again today a year on. No where near the contamination it had last year.
Worthwhile doing once a year in my book. Keeps performance tip top. ðŸ‘🻠Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
If you want to see markup, I've just replaced the MAP sensor on my Mini, I bought a genuine MG-Rover one for £78, RRP is £150. However Land Rover also use the same sensor on the D1 2ltr MPi, Freelander 1.8 and the AC system of the D2. Exact same sensor, they even still use the Rover Group part number MHK100600 - £340 from Land Rover! |
Really is beyond a joke isn't it.
I'd be inclined myself to stick to Bosch part numbers myself as they definitely are the manufacturer. Failing that LR or Ford but you will get the price tag applicable and manufacturer could differ. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
I'm with you on this one Steve. I always give the MAP and MAF (TD5) clean using the same method as you once a year as part of the service. They're generally not that dirty, and even if there's an element of placebo on my part, it costs nothing and makes me feel better! Following your lead, I took pics of both and I'll post them shortly as it may help others. They are probably both the originals. It is that time of the year - annual service before I head south for the family hols - but I must stop tinkering as I just changed my drive belt this morning and the tensioner has now given up the ghost! It was the fuel pump last week ![]() Cheers, Will |
Yes, by all means add up info on the TD5 too.
Mines a 2.4. They are the original sensors on mine, no issues so cleaning does the job fine. ![]() Big Brother is Watching. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
Cheers Steve,
As promised, TD5 MAP and MAF sensors - part numbers, serial numbers. Might be useful to someone ![]() ![]() Click image to enlarge ![]() Click image to enlarge |
Oops
![]() They're poor quality pics. Looked OK on my phone ![]() |
