Home > Td5 > Crank sensor failing symptoms?
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
As the title really. Anybody know what symptoms, if any a failing crank sensor would throw up?
I have an annoying problem of "jerkiness" when applying or releasing the throttle from or back to tickover, so worse in crawling traffic when trying to maintain slow speeds. It's as if the accelerator pedal doesn't work for the first 10mm of travel and the revs either jump or drop to catch up with the position of the throttle.
Thanks in advance
James 2002 110 td5
Post #614940 6th Apr 2017 5:29pm
bob neville
James
My crank sensor did not fail but the shim was missing on mine. The main symptom on mine was a flat spot at 2000 rpm which you could drive through but it was very noticeable.
Not sure if this is of any use.
2013 Defender 90 CSW - sold
Post #614943 6th Apr 2017 6:02pm
mk1collector
Not in the defender but in my youth I had a mk2 cavalier which had very similar symptoms which turned out to be splits in the air intake pipes. Don't know if it will help but worth checking. Ray
My build thread
Post #614944 6th Apr 2017 6:06pm
Are you sure that's not just slack in the drivetrain?
The Defender by nature has quite a bit, mine does the same thing pretty much and always has. WeWillWin🇬🇧🇺🇸
Post #614949 6th Apr 2017 6:13pm
barbel jim
I'd look at the accelerator first. No experience with them but believe I've read somewhere about thgem working n resistence. I also think theres 2 types for a TD5
On my cossie when the crank sensor failed it wouldnt start let alone run
Post #614959 6th Apr 2017 6:49pm
Do you ever notice any changes with gear changes associated too?
Clutch switch maybe something to do with it... WeWillWin🇬🇧🇺🇸
Post #614961 6th Apr 2017 6:51pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I'm with Custon90Steve on this, check all splines and axles, u-joints and diff play. Once you get the driveline tight if its still present conisder DMF. What's your mileage? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #615051 7th Apr 2017 12:00am
Jimb1978
I've checked the drive flanges and props. It had a new gearbox and dmf at 72000 and is currently on 94000. I haven't looked at the diff or transfer box but with a wheel jacked up there doesn't seem to be excessive play.
The main reason I suspected something electrical is that once the engine is warm the problem all but disappears.
How do I check play within the diff or transfer box? How much rotation at the flanges before it moves the other end is "normal"?
I've owned a couple of high mileage defenders and discoveries and neither had this problem, both 300 tdi 2002 110 td5
Post #615068 7th Apr 2017 7:28am
excossack
If its any help I get similar, replaced the throttle pedal for LR gen item and I still have at least 10mm (maybe more) of travel on the pedal before any revs pick up).
If I don't lift off the pedal all the way and change gear I can get a smoother gear change.
Other times its like a lag between me pressing the pedal and then a clunk.
FWIW I have a 99' 110 Td5 with a 10p engine. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #615077 7th Apr 2017 8:20am
Caterham
I think I'm right in saying that the workshop manual suggests the cps is only monitored for start up?
Post #615094 7th Apr 2017 9:51am
No, that's the camshaft position sensor (needed at startup since the camshaft rotates once for every two revolutions of the crankshaft, and the ECU has to know which stroke the engine is on).
Correct operation of the crankshaft position sensor is essential for the operation of the engine, and failure of the crank position sensor is a common cause of complete engine stoppage problems on modern engines - the engine won't run without it.
Post #615095 7th Apr 2017 10:02am
Caterham
Bow down
thanks for confirming BW.
Off Topic by the way. I'm planning on getting my truck running sweet if it's the last thing I do. I know full well how beautifully it can run. after having another adapter shaft replaced recently I'm on a borrowed transfer box. Mine's off to be rebuilt and strengthened along with a kinda lsd in the middle, once back it'll be fitted to a new gearbox (and adapter shaft if there's any suggestion of wear), the rear diff is also be rebuilt with lsd and I'm having the rail sensor and vcv being looked at today as the engine seems to be hunting more regularly than ever on tick over at the moment (+/- a good 50 rpm which to me doesn't seem like much but listening to it, it sounds very wrong.
so another 8 weeks or so and there should be a big Very Happy from my corner.
Post #615098 7th Apr 2017 10:09am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Just for info - on TD5 there is only crank shaft position sensor. There is not any sensor on cam shaft.
And for basic run TD5 needs only the crank shaft position sensor - to be able to run on idle. And gas pedal, to change the RPM form idle. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #615723 10th Apr 2017 8:20am
Swine&Small
Hi Mad Tom
Thought Drobek was Czech for Breadcrumb Twisted Evil
S&S 1983 Series 3 Pick up in Marine Blue
1967 Morris Traveller
1966 Morris Convertible
2012 VW T5 Camper
Quod Abundat Non Obstat.
Post #615733 10th Apr 2017 9:58am
MadTom
Yes, you are right, Discovery 2 is a small car. Even Def 130 is a small car. Mr. Green "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #615768 10th Apr 2017 1:35pm
