Home > Maintenance & Modifications > Levelling 110's Rear End
hank
I have a 110 DCPU, the rear end of which is noticeably higher than the front. The rear ride quality is also hard and crashy (without load) so I would like to change the rear springs for something softer and lower.
I have read of people using 90 rear springs on the front but as my front end ride quality is fine and I don’t want ‘lift’ I don’t really want to go down this route.
After extensive research I have tied myself in a knot. There is so much conflicting information out there that I now have no idea what is what!
I have the brown/purple USW 110 Utility RKB101111 springs at the rear and read that it is as simple as changing to white/green/green CSW 110 7 Seat RKB500300 but apparently while these are softer, they are also longer which results in the same ride height/occasionally a higher rear end?!
Here is a photo of my current situation, if anybody is able to recommend springs to level out the rear it would be really appreciated
List of threads I've read for info
http://www.defender2.net/forum/topic13312.html
http://www.defender2.net/forum/topic49065.html
http://www.defender2.net/forum/topic48800.html
http://www.red90.ca/rovers/springinfo.html
http://forum.landrovernet.com/showthread.p...ar-Springs
Post #614839 6th Apr 2017 8:12am
sako243
Carry a couple of bags of sand in the back?
My father used to keep a paving slab in the back of his MGB which massively helped with traction in the winter time. Rolling Eyes Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #614840 6th Apr 2017 8:21am
hank
Additional information: I don't want to carry a couple of bags of sand in the back Laughing
Post #614843 6th Apr 2017 8:31am
sako243
How often do you carry weight in the back? If not regularly you could swap over to some softer springs or as a compromise I think you should be able to fit some progressive springs from a 110 CSW which will be more supple yet offer stiffer springs the lower down they get. Ed
Post #614849 6th Apr 2017 8:42am
gcc130
Not sure on the Tdci but on my old 300tdi 110 county springs were softer than utility springs and I did the opposite as I always had tools and kit in the rear of my station wagon and the rear sagged.
Post #614859 6th Apr 2017 10:13am
bankz5152
I know what you mean, I added a spare wheel and boot lid, made it much less crashy. Though remember if you put softer springs in the rear when you do carry load it'll drop it down more
Post #614863 6th Apr 2017 10:34am
hank
I rarely carry load and when I do it's not particularly weighty. If I have anything serious to haul I use a twin axle trailer with a low(ish) nose weight.
I had wheels fitted this weekend so had four boost alloys and tyres in the back and the ride was so nice and comfortable and almost level.
Wondering whether to swap for the white/green/green CSW 110 7 Seat RKB500300 springs. Although these are slightly longer they are also lower rated so perhaps they will compress more and consequently drop the ride height a bit?
Post #614875 6th Apr 2017 11:37am
sako243
I would have thought the DC is lighter at the back so putting CSW springs (although possibly more comfortable) would likely increase the rear height. Think about it - you've got less bodywork and no rear seats in there so unlikely to compress the springs any further. Ed
Post #614878 6th Apr 2017 11:43am
ericvv
Post #614886 6th Apr 2017 12:22pm
hank
Hmmm that's food for thought! Although I would prefer to adjust the rear as the front rides fine
Post #614892 6th Apr 2017 12:44pm
MartinK
Hank - have you seen my thread:
http://www.defender2.net/forum/topic49065.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #614903 6th Apr 2017 1:13pm
hank
Martin, I have and am currently in talks with Peter at coilsprings.co.uk
Post #614904 6th Apr 2017 1:17pm
Leviathan
I'm interested in the outcome of your talks with coilsprings as I'm looking to do the same with my DCPU.
Nick
Post #614910 6th Apr 2017 1:33pm
hank
Nick, I need to take some measurements of the current spring and confirm to coilsprings.co.uk that it definitely has the purple/brown springs fitted (think it does but the brown I saw may have been mud Mr. Green)
Will post fitted photos when done. There's a five week lead time so will be a little while
Post #614918 6th Apr 2017 1:45pm
MartinK
Hank
does this help:
USW 110 Utility RKB101111 Purple/Brown 409.96mm
See http://www.defender2.net/forum/topic13312.html
I also checked this when I was planning http://bilashakaflowers.com/LandroverSprings.htm Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #614931 6th Apr 2017 3:11pm
