Home > Maintenance & Modifications > Roofs: to Dynamat or not to Dynamat? That is the question!
Having recently ripped out the manky carpet that had been glued in place by the previous owner and just picked up a front head lining for a bargain price, my thoughts have turned to insulating the roof. I've got some big sheets of self-adhesive closed cell foam to stick up but I'm not sure if it's worth fitting a sound absorber, too? Since removing the carpet, the roof has a distinct 'bong' when closing the door, but will this be resolved with just CCF and a headlining?
What's the consensus?
(Incidently, I've got a box of Silentcoat to hand but it didn't sound (ha!) as slick in the title) Darren
Post #614675 5th Apr 2017 2:35pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Had mine insulated last year including the roof and its made a massive improvement not only in sound proofing but also insulating against the heat and cold. Thumbs Up
Post #614676 5th Apr 2017 2:48pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I wouldn't bother if you're going to put up foam and the headlining. I would concentrate on the floor and bonnet?
Post #614679 5th Apr 2017 3:21pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I�m going to dynamat mine when the headlining is down. My thinking is it WILL help in some way- (especially after finding the difference in doing the front of my car) and I won�t want to take the headlining down again in the future to dynamat it. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #614686 5th Apr 2017 4:27pm
Stacey007
Hello
I've done other bits of my car and its made a huge difference,
As your headlining is off and you have a box 'spare' its a no brainier I would do it.
I will do mine at some point but I hear its quite awkward removing the headlining in a 110
As other have said it will probably also keep it cooler in summer and warmer in winter Very Happy
Post #614723 5th Apr 2017 7:42pm
Thanks, all. A bit of a mixed bag on the responses so I suspect I'll stick some Silentcoat in the middle of the panels whilst I've got the chance. Darren
Post #614724 5th Apr 2017 7:58pm
Riverboy
If you have the lining off anyway, I'd stick as much as you can up there. It does make a huge difference so why not do it?
Post #614736 5th Apr 2017 8:24pm
BigRuss
I did mine with dynamats lighter version and it does take out a lot or noise, you also get that nice solid sound when you knock on the roof Mr. Green Russell
2011MY 110 XS USW Black
Post #614740 5th Apr 2017 8:32pm
