Home > Maintenance & Modifications > Roofs: to Dynamat or not to Dynamat? That is the question!
Having recently ripped out the manky carpet that had been glued in place by the previous owner and just picked up a front head lining for a bargain price, my thoughts have turned to insulating the roof. I've got some big sheets of self-adhesive closed cell foam to stick up but I'm not sure if it's worth fitting a sound absorber, too? Since removing the carpet, the roof has a distinct 'bong' when closing the door, but will this be resolved with just CCF and a headlining?
What's the consensus?
(Incidently, I've got a box of Silentcoat to hand but it didn't sound (ha!) as slick in the title) Darren
Post #614675 5th Apr 2017 2:35pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Had mine insulated last year including the roof and its made a massive improvement not only in sound proofing but also insulating against the heat and cold. Thumbs Up
Post #614676 5th Apr 2017 2:48pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I wouldn't bother if you're going to put up foam and the headlining. I would concentrate on the floor and bonnet?
Post #614679 5th Apr 2017 3:21pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
I’m going to dynamat mine when the headlining is down. My thinking is it WILL help in some way- (especially after finding the difference in doing the front of my car) and I won’t want to take the headlining down again in the future to dynamat it. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #614686 5th Apr 2017 4:27pm
Stacey007
Hello
I've done other bits of my car and its made a huge difference,
As your headlining is off and you have a box 'spare' its a no brainier I would do it.
I will do mine at some point but I hear its quite awkward removing the headlining in a 110
As other have said it will probably also keep it cooler in summer and warmer in winter Very Happy
Post #614723 5th Apr 2017 7:42pm
Thanks, all. A bit of a mixed bag on the responses so I suspect I'll stick some Silentcoat in the middle of the panels whilst I've got the chance. Darren
Post #614724 5th Apr 2017 7:58pm
Riverboy
If you have the lining off anyway, I'd stick as much as you can up there. It does make a huge difference so why not do it?
Post #614736 5th Apr 2017 8:24pm
BigRuss
I did mine with dynamats lighter version and it does take out a lot or noise, you also get that nice solid sound when you knock on the roof Mr. Green Russell
2011MY 110 XS USW Black
Post #614740 5th Apr 2017 8:32pm
