Home > In Car Electronics > Towing electric loom socket type |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
Good afternoon all,
I am currently changing my towing electrics to 13 pin using the genuine LR kit. When I removed the 7 pin loom it snapped a few of the pins off inside the plug on the loom side due to corrosion. This is the towing electric side - I'm after the other part that is part of the main loom Click image to enlarge Does anybody know the name/type of plug on the loom? I would rather fit a new plug than solder/join 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
1st Apr 2017 11:53am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Ask PaulMc - he may have a source of the pins (your best bet rather than a full connector shell) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
1st Apr 2017 11:56am |
2015 D90 XS SW |
1st Apr 2017 11:59am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
beat me to it Martin
1st Apr 2017 12:00pm |
ideal I'll get in touch 2002 90 Td5 Station Wagon
1st Apr 2017 12:06pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 501 |
I've replied to your PM Paul.
1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
2nd Apr 2017 2:24pm |
Paul
I sent to you a PM..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
3rd Apr 2017 8:09am |
Loom plug arrived yesterday from Paul . Will be fitting it this week some time. As I don't have the correct crimping tool, are there any recommendations for a work around? 2002 90 Td5 Station Wagon
6th Apr 2017 6:26am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10751 |
What type of crimping tool do you need grafty ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
6th Apr 2017 7:44pm |
I'm sure Paul can advise the right type of tool 1988 90 Td5 NAS soft top
2015 D90 XS SW |
6th Apr 2017 7:45pm |
As it's a hybrid connector there are two sized connectors. They are similar to the pins in the lighting plugs 2002 90 Td5 Station Wagon
6th Apr 2017 8:47pm |
Something like this should do the job:
Click image to enlarge For example: http://www.ebay.co.uk/itm/Uninsulated-Term...SwDN1UT2ad Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Apr 2017 9:19pm |
Ideal thanks Paul 2002 90 Td5 Station Wagon
7th Apr 2017 6:47am |
