![]() | Home > In Car Electronics > Towing electric loom socket type |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Good afternoon all,
I am currently changing my towing electrics to 13 pin using the genuine LR kit. When I removed the 7 pin loom it snapped a few of the pins off inside the plug on the loom side due to corrosion. This is the towing electric side - I'm after the other part that is part of the main loom ![]() Click image to enlarge Does anybody know the name/type of plug on the loom? I would rather fit a new plug than solder/join ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6635 ![]() ![]() ![]() |
Ask PaulMc - he may have a source of the pins (your best bet rather than a full connector shell)
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 ![]() ![]() |
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 504 ![]() ![]() ![]() |
I've replied to your PM
![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Paul
I sent to you a PM..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Loom plug arrived yesterday from Paul
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10859 ![]() ![]() |
What type of crimping tool do you need grafty ? Clayton.
I'm sure Paul can advise the right type of tool
As it's a hybrid connector there are two sized connectors. They are similar to the pins in the lighting plugs
Something like this should do the job:
![]() Click image to enlarge For example: http://www.ebay.co.uk/itm/Uninsulated-Term...SwDN1UT2ad Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Ideal thanks Paul
