Home > Puma (Tdci) > Gearbox oil..recommendations please. |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
I would talk to Opie Oils on this forum, I think they are a site sponser and gurus for all things oily 👍
30th Mar 2017 9:48pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 918 |
Although I could be wrong, Red oil suggests that they have put ATF in it
Really the factory spec is a Castrol BOT 130 but many on here including myself have used Castrol Syntrans 75W-90 I got mine from opie oils as linked the refil amount is 2.2 litres although after having the wrong stuff in there I would be inclined to at least once do a drain and refil to flush it out. |
30th Mar 2017 10:21pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
GL-4 (not 5) 75W-90. 2.2 l Puma 110" SW
30th Mar 2017 10:54pm |
Although ATF isn't recomended for the MT82, some manual gearboxes do use it, so i don't think it'll do much real harm in the short term Comma do a gear oil to the right spec too. http://www.commaoil.com/passenger-vehicles/products/view/550 |
31st Mar 2017 4:05am |
A whiles back I compared the specifications of the syntrans type with the BOT 130 and came out wondering if they were the same thing. Perhaps just a small additive or two difference? I've been running for the last year on it anyways, works for me Solved the bowel problem, working on the consonants... |
31st Mar 2017 5:47am |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 226 |
Thanks guys for the prompt replies, The gearbox would appear to be using a Redline MT90 gl4 oil, which on some of the Mustang forums, have mixed reviews.
As suggested , i will check in with the chaps in Opie oils, as this particular oil is on their stock list. |
31st Mar 2017 9:55am |
It was more the fact that even today a garage is able to put the wrong oil in. Next the OP will be telling us that the garage didn't use a C1 specific oil just any old 5W-30 or even 5W-40 they had on the shelf. |
31st Mar 2017 10:18am |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
Just go to a Landrover dealer and buy 3L of the proper Castrol stuff - those puma gearboxes don't like anything else.
Mark |
31st Mar 2017 11:44am |
Thanks again guy, I'm sure the engine oil should be fine after the recent recall on the oil pump. but thanks anyway...
31st Mar 2017 12:45pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
I replaced the Castrol stuff with the Motul equivalents, based on good feedback from Oz.
Both gearbox & transfer case run more smoothly and not as hot either. Gearbox: Motul Gear 300 75w90 : http://www.motul.com/za/en/products/oils-l...-300-75w90 Transfer box: Motyl Gear 75w90: http://www.motul.com/za/en/products/oils-l...gear-75w90 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ Last edited by Naks on 3rd Apr 2017 7:41am. Edited 1 time in total |
31st Mar 2017 12:47pm |
WeiB.beer Member Since: 13 Apr 2016 Location: Hertfordshire Posts: 58 |
Naks, is there any reason you opted for semi-synthetic for the transfer case when you went for fully synthetic in the gearbox?
I only ask because I have just bought Motul Gear 300 for both gearbox and transfer case and just want to make sure I wasn't about to make a mistake! 2015 110 Defender Heritage Utility Station Wagon 2014 B8 Audi RS4 2003 Audi A2 1.4 Tdi |
31st Mar 2017 1:26pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 248 |
I was doing some homework on stiff gearchanges in a cold box and theres a ford service bulletin about replacing the fluid to something called dual clutch fluid.
maybe that's what you've got? read -- http://mustangsdaily.com/blog/wp-content/u...-03-18.pdf 1953 80" 1987 mini city e 2011 90" |
2nd Apr 2017 8:21pm |
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 |
Devon 4x4 put ATF in my MT82 box. Better on the syncos apparently. Feels fine to me. Think its Fuchs Titan ATF 4000..... 2009 2.4TDCi XS Utility Wagon.
2nd Apr 2017 8:31pm |
I recall discussion about some material in the MT82 not liking standard oils and degrading over time.
i.e. what might feel fine might not be best over time... Solved the bowel problem, working on the consonants... |
2nd Apr 2017 9:12pm |
