Home > Puma (Tdci) > 110 Rear Mudflap Bracket Replacement Advice
Galyman
Scotland 2013 Defender 110 Puma 2.2 HT Aintree Green
Hi
I need to replace my RH rear mud flap bracket on my 2012 110. My searches for brackets only do not seem to cover vehicles up to this age so am thinking i might need to buy a bracket + flap combo. The current flap is fine but is pretty well connected to the offending bracket. i will also be getting myself some reinforcing brackets to make sure they stay put.
Any advice welcome
Post #613382 30th Mar 2017 7:48pm
Morepower
New Zealand
I've got a 2013 110 USW... I have a set of the Entreq bracket mounting strengtheners and a set of Stainless powder coated mud flap brackets from Brendan at 4x4 Overland
Excellent set up
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #613414 30th Mar 2017 8:40pm
zsd-puma
The rear flap and bracket is the same on all the Defender 110's, it's not a great design and lots of mud just gets chucked over the top of the flap. If you buy one for an earlier car they'll fit. They're not that expensive from Land Rover. Problem is chances are it's damaged the body where it attaches on the outer end, so you'll need a repair kit.
I fitted a set of these.....
https://gwynlewis4x4.co.uk/product/defende...ub-gl1003/
Expensive, but well worth the money, they also take care of the damaged body fitting.
Post #613479 31st Mar 2017 4:00am
ericvv
These Offroad Tec SS brackets here are excellent for a 110 Puma
http://offroad-tec.de/shop/main_bigware_34...ems_id=158
Removing the mudflap from the old bracket is easy, carefully drill into the rivets until they start spinning and can be removed. You reinstall the mudflap on the new bracket with the provided SS nuts and bolts. The little SS reinforcement brackets are available from either Entreq or Brendan.
All explained and shown in page 3 of below thread.
http://www.defender2.net/forum/topic42690-30.html
Eric
Edit - I forgot, but these Offroad-TEC brackets actually come with their own reinforcement bracket included. No need to buy a separate reinforcement bracket anymore. I installed the Offroad-TEC brackets in combo with the Entreq reinforcement brackets, but that is just because I had these already in use many years before I installed those Offroad-TEC brackets. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #613481 31st Mar 2017 4:09am
Galyman
Excellent, thanks for all your responses. Much appreciated.
Post #613536 31st Mar 2017 10:11am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I second this, gwyn lewis stuff is great. Just wish he would get around to finishing his design for rear 90 flaps. However the 90 doesn't have the same issues as the 110.
Post #613545 31st Mar 2017 10:39am
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
you may find the captive nuts spin when you try to remove them, so budget time to cut/drill the old fixings, and rivnut a few new ones in place.
ask me how I know Whistle My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #613561 31st Mar 2017 11:39am
Galyman
I think I can most likely guess....
Post #613589 31st Mar 2017 1:14pm
